I don’t know what would be a better forum to ask this question, so I’ll ask it here. I’ve tried to make a C program which will output a WAV file containing the octave, each note lasting one second. However, for some reason, which I haven’t been able to find for hours now, the WAV file won’t open.
#include <stdint.h>
#include <stdio.h>
#include <math.h>
int main() {
FILE *wav=fopen("example.wav","wb");
fprintf(wav,"RIFF");
const int sampleRate=8192;
int32_t ChunkSize=36+8*sampleRate*2;
fwrite(&ChunkSize,4,1,wav);
fprintf(wav,"WAVEfmt");
int32_t Subchunk1Size=16; //PCM header is always 16 bytes
fwrite(&Subchunk1Size,4,1,wav);
int16_t AudioFormat=1; //PCM
fwrite(&AudioFormat,2,1,wav);
int16_t NumChannels=1; //MONO audio.
fwrite(&NumChannels,2,1,wav);
int32_t SampleRate=sampleRate;
fwrite(&SampleRate,4,1,wav);
int32_t ByteRate=2*sampleRate;
fwrite(&ByteRate,4,1,wav);
int16_t BlockAlign=2;
fwrite(&BlockAlign,2,1,wav);
int16_t BitsPerSample=16;
fwrite(&BitsPerSample,2,1,wav);
fprintf(wav,"data");
int32_t Subchunk2Size=ChunkSize-36;
for (int i=0; i<8*sampleRate; i++) {
float currentFrequency;
if (i<=sampleRate)
currentFrequency=262; //The C tone is 262Hz.
else if (i>sampleRate && i<=2*sampleRate)
currentFrequency=294; //The D tone is 294Hz.
else if (i>2*sampleRate && i<=3*sampleRate)
currentFrequency=330; //The E tone is 330Hz.
else if (i>3*sampleRate && i<=4*sampleRate)
currentFrequency=349; //The F tone.
else if (i>4*sampleRate && i<=5*sampleRate)
currentFrequency=391; //The G tone.
else if (i>5*sampleRate && i<=6*sampleRate)
currentFrequency=440; //The A tone.
else if (i>6*sampleRate && i<=7*sampleRate)
currentFrequency=494; //The H sound.
else
currentFrequency=523; //The Tenor C.
float baseFrequency=sin(2*M_PI*currentFrequency*i/sampleRate)*16384;
float secondHarmony=sin(2*M_PI*2*currentFrequency*i/sampleRate)*4096;
float thirdHarmony=sin(2*M_PI*3*currentFrequency*i/sampleRate)*41024;
float currentAmplitude=baseFrequency+secondHarmony+thirdHarmony*exp(-(float)(i%sampleRate+2000)/2000);
int16_t numberToBeWritten=currentAmplitude;
fwrite(&numberToBeWritten,2,1,wav);
fclose(wav);
Can you guess what’s going on here? I can’t.
