Using version 3.2.5 and trying to export a 5.1 AC3 file using ffmpeg for Audacity.
During playback, all 6 tracks play perfectly fine , however when I go to export the file, the audio from the sixth channel can only be heard from the right side (cannot hear it from the left side).
My notes (from an experiment I did with with a test disc) say track 6 is right surround (right rear) so it shouldn’t be coming out of the left.
1= Left
2= Right
3= Center
4= LFE
5= Left Surround
6= Right Surround
I didn’t actually try exporting the file though… That’s what I got when I opened it in Audacity.
Several years ago when I was making some DVDs I used wavtoac3encoder which takes 6 WAV files and there is a “wizard mode” that makes it easy assign a WAV file to a particular channel.
