hello
how do I create a 40hz isochronic tones sound in the gamma wave range ?
thank you
hello
thank you
You could try the “Isochronic modulator” plug-in: https://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#Isochronic_modulator
hi … thank you but the isomod plugin has an isochronous sound rate up to 20 hz … how do I go up to 40 hz ?
You could modify the plug-in by changing the lines:
;control startf "Initial Modulation Frequency" real "Hz" 7 1 20
;control endf "Final Modulation Frequency" real "Hz" 2 1 20
to
;control startf "Initial Modulation Frequency" real "Hz" 7 1 40
;control endf "Final Modulation Frequency" real "Hz" 2 1 40
great … amazing … thank you …
