I just upgraded my Audacity to version 3.2.2. I have a MacBook Air OS 10.15.7. Since upgrading, audacity will not pick up a signal from my microphones. XLR, USB, and the built in microphone will not record. All were selected separately as the input source. I attached a screen gab of the problem.
Does Audacity have permission to use the “microphone”? See https://forum.audacityteam.org/t/no-recording-level/51788/1
– Bill
Ever since I “upgraded” to 3.2.0, I haven’t been able to record or even see any incoming level! And yes, my Microphone setting is on for Audacity and a couple of DAWs.
Mac mini (2018)
3 GHz 6-Core Intel Core i5
32 GB 2400 MHz DDR4
OS 12.6
Thank YOU!
I am up and running again!!!
Is this with your MOTU 828? Have you tried any support forums that might exist for MOTU?
– Bill
Aside from various issues I’m having with my 828x, I can get audio recorded through this into DP 11. It’s Audacity that’s not able to see ANY input level, even through the same channels that the 828x is able to record on!
