I needed to batch fade/in out around 1,000 wavs to remove some very subtle clicks in a sample library I purchased. I managed to do it using Audacity and the fade-io.ny plugin but during the batch process all wavs are exported as 16 bit rather than their original 24 bit format.
Is this a limitation of batch exporting? The only reference I could find was something about first manually exporting a single wav and using the “Other uncompressed files” option and selecting 24 bit, after which Audacity should remember the last format used. But this didn’t make any difference and it still exports wavs as 16 bit.
If you want to “vote” that Chains support “Other uncompressed files” we can record your vote (anonymously). To some extent we take number of votes into account when considering new and improved features.
