I just updated to 3.6.4 and even though I can ‘Add’ a plugin folder, I can’t stop it scanning the default locations such as C:\program files\cakewalk\vstplugins or C:\program files\steinberg\vst and when the scan cannot find these locations it throws an error “plugin location not found” or “plugin not found at location” and the only option that’s presented is to ‘Quit Audacity’.
The 2nd let down is that Audacity is NOT friendly to 3rd party VST’s, such as Addictive drums/keys, well, in fact this is a list of all the VST’s that the scan rejected and disabled, there are a few that I have purchased and some are freeware, and yes these VST’s are 64 bit to match Audacity being 64 bit:
C:\Program Files\Cakewalk\VstPlugins\APC.dll
C:\Program Files\Cakewalk\VstPlugins\Absynth 5 Stereo.dll
C:\Program Files\Cakewalk\VstPlugins\Absynth 5.dll
C:\Program Files\Cakewalk\VstPlugins\Plogue Art et Technologie, Inc\sforzando VST_x64.dll
C:\Program Files\Cakewalk\VstPlugins\RealLPC.dll
C:\Program Files\Cakewalk\VstPlugins\SI-Bass Guitar\SI-Bass Guitar.dll
C:\Program Files\Cakewalk\VstPlugins\SI-Drum Kit\SI-Drum Kit.dll
C:\Program Files\Cakewalk\VstPlugins\SI-Electric Piano\SI-Electric Piano.dll
C:\Program Files\Cakewalk\VstPlugins\SI-String Section\SI-String Section.dll
C:\Program Files\Cakewalk\VstPlugins\XLN Audio\Addictive Drums\Addictive Drums x64.dll
C:\Program Files\Cakewalk\VstPlugins\XLN Audio\Addictive Keys.dll
C:\Program Files\Common Files\VST3\Kontakt.vst3;5653544E6924446B6F6E74616B740000
C:\Program Files\Common Files\VST3\TyrellN6(x64).vst3;D39D5B69D6AF42FA1234567874596E36
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443564535697233363020736F75
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443564536697233363020736F75
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443564554697233363020656666
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443564559697233363020736F75
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443564654697233363020736F75
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443565135697233363020656666
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443565136697233363020656666
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443565154697233363020656666
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535443565159697233363020646973
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535444554653647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;565354444D4C54647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535444444D54647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535444444D55647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535444555046647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535444555054647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535444555055647473206E65757261
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525335682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525336682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525354682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525355682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525359682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;5653544852535A682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525635682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525636682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525654682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525655682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;56535448525659682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;5653544852565A682D72657665726220
C:\Program Files\Common Files\VST3\WaveShell1-VST3 10.0_x64.vst3;5653544A464753656C656D656E742073
C:\Program Files\Common Files\VST3\iZotope\iZVinyl.dll
C:\Program Files\Common Files\VST3\sforzando.vst3;5C5CA79682FC437AB6539BA204BAB349
C:\VSTPlugins64\Band-in-a-Box DAW VST Plugin.dll
C:\VSTPlugins64\Creepy Piano 3 Lite.dll
C:\VSTPlugins64\FL Studio VSTi (Multi).dll
C:\VSTPlugins64\FL Studio VSTi.dll
C:\VSTPlugins64\Kontakt.dll
C:\VSTPlugins64\Satellite MIDI.dll
C:\VSTPlugins64\Satellite Sessions.dll
C:\VSTPlugins64\Synapse Audio\DUNE 3.dll
C:\VSTPlugins64\Toontrack\EZbass.dll
C:\VSTPlugins64\TyrellN6(x64).dll
C:\VSTPlugins64\VstPlugins\VB3-II.dll
C:\VSTPlugins64\iZVinyl.dll
