Running Windows 7 - completely up to date as of September 30, 2014
Audacity version 2.0.6
Downloaded the .exe version
Log shows errors from installation:
7:04:30 AM: Audacity 2.0.6
7:04:30 AM: Trying to load FFmpeg libraries…
7:04:30 AM: Trying to load FFmpeg libraries from system paths. File name is ‘avformat-55.dll’.
7:04:30 AM: Looking up PATH environment variable…
7:04:30 AM: PATH = ‘C:Program Files (x86)SeaMonkey;C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Program Files (x86)Common FilesMicrosoft SharedWindows Live;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program Files (x86)Windows LiveShared;C:Program Files (x86)Common FilesRoxio SharedOEMDLLShared;C:Program Files (x86)Common FilesRoxio SharedOEMDLLShared;C:Program Files (x86)Common FilesRoxio SharedOEM12.0DLLShared;C:Program Files (x86)RoxioOEMAudioCore;C:Program Files (x86)GNUGnuPGpub;C:Program Files (x86)QuickTime AlternativeQTSystem’
7:04:30 AM: Checking that ‘’ is in PATH…
7:04:30 AM: FFmpeg directory is in PATH.
7:04:30 AM: Checking for monolithic avformat from ‘avformat-55.dll’.
7:04:30 AM: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: the specified module could not be found.)
7:04:30 AM: Loading avutil from ‘’.
7:04:30 AM: Error: Failed to load shared library ‘.dll’ (error 126: the specified module could not be found.)
7:04:30 AM: Loading avcodec from ‘’.
7:04:30 AM: Loading avformat from ‘avformat-55.dll’.
7:04:30 AM: Error: Failed to load FFmpeg libraries.
7:04:30 AM: Error: Failed to find compatible FFmpeg libraries.
Should these files be part of the installation package?
