[2.0.0/Win] Extracting sound from SWF file?
Hello
Audacity is apparently unable to play SWF files. Is there an add-on I could use?
FWIW, I also tried VLC (1.x and 2.x), but it crashes when I load the SWF file.
Thank you.
The best you can do is install the FFMpeg software. That allows Audacity to recognize and process a very wide range of content, however, if VLC couldn’t deal with it, that’s not a good sign.
Have a look at the following free software:
http://www.freemake.com/free_video_downloader/?from=app
http://www.milosoftware.com/en/index.php?body=soundleech.php
http://www.eolsoft.com/freeware/flash_movie_player/
Thanks for the links.
If your computer supports it, you could try playing the SWF file in a suitable player program and then capture the sound from “Stereo Mix”.
