So I have noticed a few of us have had playback memory leaks from recording and using a generated metronome on audacity. The simplified fix I’ve come up with is export just the metronome at the length you want it as an mp3, then import that mp3 back into Audacity. Should be a good work around until the Devs fix the bug.
