No stereo recording
Help for Audacity on macOS.
sensational fix
Re: No stereo recording
Post by sensational fix » Thu Apr 15, 2021 5:38 pm
Mmm.. no, it's a professional mixer: https://www.pioneerdj.com/es-es/product ... /overview/
Post by steve » Thu Apr 15, 2021 5:40 pm
Have you installed the latest drivers for that mixer? For Big Sur you need the "Version3.0.0" drivers (updated 04/Feb/2021)
sensational fix
Post by sensational fix » Fri Apr 16, 2021 7:16 am
Yes, I did it yesterday. Unluckily issue continues.
Captura de pantalla 2021-04-16 a las 9.14.05.png (238.88 KiB) Viewed 263 times
Post by steve » Fri Apr 16, 2021 1:46 pm
Audacity records from the computer's sound system, and the sound system is showing (in "Audio MIDI setup") that the device only has a "left" input channel, so that's all that Audacity sees.
There may be a switch somewhere on the mixer to select mono / stereo, or there may be a fault with the mixer. I'm not familiar with that mixer, so your best chance of finding / fixing the problem is likely to be either the mixer's user manual, or Pioneer support.
sensational fix
Post by sensational fix » Fri Apr 16, 2021 4:46 pm
Right, seems it's a Macbook Air issue. Just left channel receives sound, 2 channels out, 1 in. Pretty ridiculous considering it's not a cheap computer.
Thanks!
sensational fix
Post by sensational fix » Mon Apr 19, 2021 9:47 am
Changed my Mac, now working on a Pro and the problem persists. Seems not an issue from the Air set up. Is there anything else you would recommend to check out?
Post by steve » Mon Apr 19, 2021 10:56 am
Try doing a "factory reset" of your DJM-750
sensational fix
Post by sensational fix » Tue Apr 20, 2021 6:51 am
Not working either. Looks like I have no other option than recording in digital and end my relation with Audacity :(
Post by steve » Tue Apr 20, 2021 12:22 pm
What do you mean?
sensational fix
Post by sensational fix » Tue Apr 20, 2021 3:58 pm
Ableton / Traktor or similar
