I want to be able to take any given audio track and automatically create a selection from the end of the track to the nearest whole second. For example, if I have a track that ends at 3.6 seconds, I would want a selection from 3.6 - 4.0 seconds, without any user input required. Is this possible to do with a Python script in Audacity?
This script is written for Linux. It’ll need a bit of modification for Windows (see: https://github.com/audacity/audacity/blob/master/scripts/piped-work/pipe_test.py)
#!/usr/bin/env python
# -*- coding: utf-8 -*
import os
import json
TONAME = '/tmp/audacity_script_pipe.to.' + str(os.getuid())
FROMNAME = '/tmp/audacity_script_pipe.from.' + str(os.getuid())
TOFILE = open(TONAME, 'w')
FROMFILE = open(FROMNAME, 'rt')
def send_command(command):
TOFILE.write(command + "\n")
TOFILE.flush()
def get_response():
"""Return the command response."""
result = ''
line = ''
while True:
result += line
line = FROMFILE.readline()
if line == '\n' and len(result) > 0:
break
return result
def do_command(command):
"""Send one command, and return the response."""
response = get_response()
return response
command = "GetInfo: Type=Tracks"
info = (do_command(command))
#Trim info to JSON data
info = info[1:-26]
track_data = json.loads(info)
first_track_end = track_data[0]["end"]
start = int(first_track_end)
end = start + 1
# Send command
command = 'SelectAll:'
command = f'SelectTime: Start={start} End={end}'
Not what you asked for, but it’s a lot simpler with a “Nyquist Macro” https://manual.audacityteam.org/man/nyquist_macros.html
Select part, or all of the track, then run this in the Nyquist Prompt (https://manual.audacityteam.org/man/nyquist_prompt.html)
It’ll be quite slow the first time that you run it, but faster after the first run.
;type tool
(setf end (second (assoc 'end (first (aud-get-info "Tracks")))))
(setf start (truncate end))
(setf end (1+ start))
(aud-do-command "SelectTime" :start start :end end)
An alternative Python script using pipeclient (See: https://github.com/audacity/audacity/blob/master/scripts/piped-work/pipeclient.py)
import json
import time
import pipeclient
client = pipeclient.PipeClient()
client.write('GetInfo: Type=Tracks')
# Wait for reply
info = ""
while info == "":
info = client.read()
time.sleep(0.05)
info = info[:-26]
#print('Info: ', info)
end = start + 1
client.write('SelectAll:')
client.write(f'SelectTime: Start={start} End={end}')
