Every day I have a new folder of MP3 files that I need to concatenate and strip long pauses from. My needs are quick/dirty, so I’d rather not get into waveforms. Can anyone offer guidance re: scripting this? Unfortunately, I’m not able to use anything deeper than applescript/automator.
If it can’t be scripted, is there an optimal workflow that will make this as efficient as possible?
I’m on a Mac (but felt the query belonged here rather than on the MacOS board)
How long are the supplied pauses and how long do they need to be?
Are the supplied pauses “clean?” Do they drop to absolutely no sound, or do they have hummy, buzzy, shuffling, background sound, Room Tone in the pauses?
One of the problems with automating a “Dirty” (noisy) track, is you have to play the whole thing anyway to make sure it worked right.
The “Truncate Silence” effect has had a minor update. In the old version, the first control was called “Level”. In the new version the first control is called “Threshold”. There’s no difference in what they do.
