Hi All,
Upon reviewing other posts, I followed the suggestion to create a voice test file and submit for feedback. I have no idea where to even start. It seems like everything I do ends up making the ambient background noise worse without doing anything to clarify the voice.
Windows 10
Audacity 2.4.2
Mic: Hayner Seek USB Mic
My buddy records using the same mic directly into audacity and sounds a TON better right from the jump. Any advice is helpful. The forums are…byzantine.
