The ubuntuhanbook1 PPA build is currently broken. If you have problems with that version, please report it to the PPA maintainer.
To revert back to a working version of Audacity:
- Completely remove “audacity” and “audacity-data” packages.
- Remove or disable the ubuntuhanbook1 PPA from your sources.
- Reinstall the older version of Audacity from the main Ubuntu repository.
- Report the problem to the PPA maintainer.
This announcement will expire in 14 days.
