cannot input Chinese of Japanese at the label track
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by joimage » Wed Aug 30, 2017 2:35 am
I've been using Audacity 2.0.6. When pressing command+B, I can add labels and input text in Chinese, Japanese or English.
But after update to 2.1.3, only English text can be inputted even I use Chinese or Japanese input method.
Could anyone help me to solve this problem? Thanks a lot.
joimage
Re: cannot input Chinese of Japanese at the label track
Permanent link to this post Posted by steve » Wed Aug 30, 2017 10:28 am
joimage wrote:after update to 2.1.3, only English text can be inputted even I use Chinese or Japanese input method.
Do you mean that you can create the label but you can't type Chinese or Japanese characters, or do you mean that the keyboard shortcut (Command + B) does not work when you change the input method.
If you mean that you can't type into the label, can you paste Chinese / Japanese into the label?
If you mean that the keyboard shortcut does not work, does the menu command "Tracks Label > Add Label at Selection"?
Permanent link to this post Posted by joimage » Thu Aug 31, 2017 11:17 am
Thanks for the reply. I can create the label but can't type Chinese or Japanese characters.
Also I can paste Chinese / Japanese into the label, but it will better if I can type them directly as I did when using 2.0.6.
joimage
Permanent link to this post Posted by steve » Thu Aug 31, 2017 9:08 pm
I've just tested Audacity 2.1.3 on Sierra, and it appears to accept typing Chinese characters in labels (though I don't read / write Chinese so I've no idea if they are the right characters).
Are Chinese / Japanese input methods working correctly in other applications?
Permanent link to this post Posted by joimage » Mon Sep 04, 2017 12:21 pm
Yes, they work fine in applications. By the way, I'm using Macbook Pro.
joimage
Permanent link to this post Posted by joimage » Mon Sep 04, 2017 2:56 pm
Please see the attachment. Chinese or Japanese input doesn't work in Audacity 2.1.3 as they did in 2.0.6
螢幕快照 2017-09-04 23.51.00.png (480.93 KiB) Viewed 592 times
Reason: place image inline to preserve board layout
joimage
Permanent link to this post Posted by steve » Mon Sep 04, 2017 4:14 pm
joimage wrote: I'm using Macbook Pro.
Which version of Mac OS?
Permanent link to this post Posted by joimage » Tue Sep 05, 2017 1:48 am
It's macOS Sierra 10.12.6
joimage
Permanent link to this post Posted by steve » Tue Sep 05, 2017 4:36 pm
I don't know why it doesn't work for you with Audacity 2.1.3 on Sierra when it does work for me with Audacity 2.1.3 on Sierra.
You could try the new "Audacity 2.2.0 beta" to see if that works for you. Details about 2.2.0 beta are on the website here: https://www.audacityteam.org/beta-versi ... available/
Permanent link to this post Posted by joimage » Wed Sep 06, 2017 1:35 am
Thank you very much! I'll try 2.2.0.
joimage
Next
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
