version 3.0.0
Help for Audacity on macOS.
charlen
Operating System: macOS 10.12 Sierra
version 3.0.0
Post by charlen » Fri Mar 19, 2021 10:17 am
hello
i would like to know [ to be sure ] if this version works fine with mac os 10.12.6
thanks to let me know
Re: version 3.0.0
Post by steve » Fri Mar 19, 2021 2:23 pm
macOS 10.12 is not officially supported by Audacity 3.0.0.
If you decide to try it, you are welcome to post back and report if / how well it works for you.
System requirements (officially supported) for macOS are listed at the bottom of the download page: https://www.audacityteam.org/download/mac/
Delphin
Operating System: macOS 10.11 El Capitan
Re: version 3.0.0
Post by Delphin » Sat Mar 20, 2021 10:00 pm
Hello,
I have unusual experiences with 3.0.0 under different, now unsupported systems:
- it still works fine (so far) under 10.11.6;
- it doesn't even launch under 10.13.6 and 10.15.7 (see screenshot of the later; I don't think translation will be necessary).
On the download page (https://www.audacityteam.org/download/) it still says 10.7 - 11.2, which should say 11.13 - 11.2, right?
And on the legacy page (https://www.audacityteam.org/download/legacy-mac/) you write of Lion 10.07.
Thank you,
Delphin
app audacity can't be launched
still system 10.7?
charlen
Re: version 3.0.0
Post by charlen » Sun Mar 21, 2021 9:06 am
hello delphin
the version 3.0.0 until now work fine with this version .
Screen Shot 2021-03-21 at 10.02.14 AM.png (27.98 KiB) Viewed 745 times
the way i use it , the composition is done step writing with " sibelius " then i use audacity for the mix .
cordialy
Delphin
Re: version 3.0.0
Post by Delphin » Sun May 02, 2021 11:30 am
Hello,
3.0.2 works fine on 10.11.6 and 10.13.6. (We don't run 10.15 anymore.)
So I can confirm what's writen on the legacy-page: working even though not supported.
Greetings,
Delphin
billw58
Re: version 3.0.0
Post by billw58 » Sun May 02, 2021 2:42 pm
I've got macOS 10.15.7 and Audacity 3.0.2 runs just fine.
-- Bill
charlen
Re: version 3.0.0
Post by charlen » Mon May 03, 2021 7:56 am
hello
some time mix up with the short cut " Command + S "
assigned to saving , and instead of saving , show me the keys binding location on the preference page
cordialy
jademan
Forum Crew
Re: version 3.0.0
Post by jademan » Tue May 04, 2021 12:08 pm
hello
cordialy
Have you tried Tools > Reset Configuration ????
charlen
Re: version 3.0.0
Post by charlen » Tue May 04, 2021 12:47 pm
hello
where is this tools " reset configurations " i do not find it .
but maybe you mean " re-import configurations ." on keybrds short cut .
Re: version 3.0.0
Post by steve » Tue May 04, 2021 12:52 pm
Assuming that you are using the current "Audacity 3.0.2" (If not, get it here and install it: https://www.audacityteam.org/download/)
The "Tools" menu is in the main Audacity menu bar, (on macOS, that's at the top of the screen), immediately after the "Analyze" menu.
