I have just spent the day working on a university project and attempted to export the file this afternoon as WAV. When I did I selected the location etc. and pressed okay, and Audacity said something like reducing it down to two channels, cannot remember exact wording. Once I clicked okay it said there was something wrong with C drive again cannot remember exactly. Suddenly my entire project disappeared! It left the bits where I had increased or decreased the volume but the blue audio bits have gone! How do I get it back?!
The latest is 2.2.2, but please check which version (look in “Help menu > About Audacity”).
If you have 2.2.2, then the problem is something different.
Are you working on a University machine, or your own personal PC?
Is the computer on a network?
That’s not normal.
Unfortunately, this particular error message is not as helpful as it might be. It just tells us that Audacity is unable to access some data that it needs to either read or write on drive C:
Is there any way you are able to take control of my computer remotely and access this please? The project I was working on that vanished, I saved the project again but Audacity and my computer both are now saying that project does not exist. I’m very confused.
Not easily, as I’m not on Windows. Also, you should be extremely cautious about allowing anyone you don’t know to take control of your computer - from a Windows machine, if you gave me access, I could easily lock you out from your computer just for a laugh (though of course I would never do that - I’m just illustrating the risk).
Unfortunately that does not tell us anything useful. The log is cleared when Audacity closes. Was that log from after the “Audacity failed to read from a file in C:.” message, or did you restart Audacity between that message and opening the log?
Unfortunately recovery is not sounding very hopeful, but if we can determine what has gone wrong then at least we will be able to avoid the problem in the future.
I’m trying to get a clear picture of what is happening.
Is this a saved project? What’s the full name of the project?
Do you have the project “.aup” file and its “_data” folder? (do you understand this question?) Where are these two items?
What happens now when you try to open the project? (precisely - step by step)
