I have disabled VST and VST3 plugins and it still does that. In fact I then disabled all plugins and it still does that. How do I disable it?
Hope you don’t mind, but as this has happened to me after upgrading to v3.2.0 i’ll be keeping an eye open on this thread.
Scooby Doo
Win 7.1
Have you tried Audacity 3.2.1 ? Audacity ® | Downloads
I do not believe there is currently a way to disable the scan.
I have just installed v3.2.1 over 3.2.0 (without uninstalling). Unfortunately the issue persists
Thanks for your report. The developers are continuing to work on rescanning issues. See here: Add a skip option + timeout to plugin validation · Issue #3802 · audacity/audacity · GitHub
and here: Scan of new plugins gets stuck · Issue #3944 · audacity/audacity · GitHub
and we are hopeful that additional solutions will become available during the next few weeks.
In the meantime, you can download older versions (e.g., 3.1.3) of Audacity here: Old Audacity versions download
