Microsoft Windows 10 Professional (x64) Build 19044.1387 (21H2)
Audacity ver: 3.1.2
Realtek Driver Version: 6.0.1.7544
Hi All,
I’m quite new to Audacity and it has worked well recording audio from videos on the internet, however over the last couple of days it simply will not record anything I play from the internet or my laptop music. I have downloaded the Zip and looked at the contents.
it is using: Selected recording device: 18 - Stereo Mix (Realtek High Definition Audio).
The log shows:
11:17:06: Audacity 3.1.2
11:17:06: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
11:17:06: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
11:17:06: Error: Failed to load avformat-58.dll (error 126: The specified module could not be found.)
11:17:06: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
11:17:06: Error: Failed to load avformat-57.dll (error 126: The specified module could not be found.)
11:17:06: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
11:17:06: Error: Failed to load avformat-55.dll (error 126: The specified module could not be found.)
11:21:08: Report generated to: C:\Users\AppData\Local\Temp\Audacity_dbgrpt-6300-20211129T111945.zip
So a lot of modules that cannot be found So anyone got any suggestions as to what I should do?
Many thanks.
