I have saved an .aup file and after that I have decided, that there was needed some change in the project, so i did it and then i have saved the same .aup file again.
My file is in the same folder, where the data folder of the project is, but i am still getting that - missing data block files - message.
Could anybody please give me some suggestion? What should I do?
Wow, that’s ancient. If you have a reason not to update to the current 3.1.2 version, I’d highly recommend that you at least update to version 2.4.2 as that has several significant bug fixes.
