Hello.
I have noticed, that link on effects page of Nyquist plugins Audacity wiki is broken. Please, could YOu send newest version of broadcast limiter III here?
Thank You.
Marco
Here it is:
RFT-Limiter-III.ny (977 Bytes)
Note that this is a “soft clipping” effect rather than a true limiter.
The “Soft Clipping” option in Audacity’s Limiter effect (https://manual.audacityteam.org/man/limiter.html) is similar, but better quality. Unless you specifically want the harmonic distortion of Broadcast limiter III, I’d recommend that you use Audacity’s Limiter effect instead.
