How do I find and locate all clicks or pops throughout an entire mp3 file by any mean or workaround?
This DeClicker plugin can isolate clicks.
If you create a duplicate track, (i.e. select the track then press “Ctrl”+“D”),
then apply the DeClicker in isolate-mode to the duplicate,
that will serve to mark out the clicks on the original track, see …
Alternatively have a look at the file in spectrogram view.
… apply the DeClicker in isolate-mode to the duplicate,
How is that supposed to do
the “Declicker” doesn’t even appear in “Effect” main menu …Help me!
Audacity does not come with DeClicker: it’s a plug-in you have to install into Audacity.
You can get a copy of the DeClicker plug-in at the bottom of this post …
Here’s how to install plug-ins into Audacity …
OK, got it now,
just it didn’t show on immediate sight, in the limited screen, instead I have to go to the bottom to scroll down and to see the rest of menu options
Thanks a lot. God bless you, ameen !
