Play at speed button, should have a small pause button beside it
why?
easier to pause n play… by mouse only,
like if you are using mouse only, everytime you want to pause you have to move mouse to Left corner pause button,
where as play at speed button, is right corner.
You could always rearrange your Toolbars so that the Play at Speed button is close to the Pause button:
(See: https://manual.audacityteam.org/man/customizing_toolbar_layout.html)
Oh, I didnt know, that it can be moved!
Thanks. this solved my problem, helped me re-arrange everything as I need
