I’m trying to build audacity on Ubuntu 18.04 following the steps from this topic “Building Audacity 2.3.1 on Ubuntu 18.04”
configure steps end with this error
-=-=-=-=-=-=-=-=-=-= Configuration Complete =-=-=-=-=-=-=-=-=-=-
Configuration summary :
libsndfile version : .................. 1.0.24
Host CPU : ............................ x86_64
Host Vendor : ......................... unknown
Host OS : ............................. linux-gnu
Experimental code : ................... no
Using ALSA in example programs : ...... no
External FLAC/Ogg/Vorbis : ............ no
Tools :
Compiler is GCC : ..................... yes
GCC version : ......................... 8
Installation directories :
Library directory : ................... /usr/local/lib
Program directory : ................... /usr/local/bin
Pkgconfig directory : ................. /usr/local/lib/pkgconfig
HTML docs directory : ................. /usr/local/share/doc/libsndfile1-dev/html
Compiling some other packages against libsndfile may require
the addition of '/usr/local/lib/pkgconfig' to the
PKG_CONFIG_PATH environment variable.
=== configuring in lib-src/libsoxr (/home/raz/Downloads/audacity-minsrc-2.3.1/build/lib-src/libsoxr)
configure: running /bin/bash ../../../lib-src/libsoxr/configure --disable-option-checking '--prefix=/usr/local/' '--with-lib-preference=local system' '--with-ffmpeg=system' '--disable-dynamic-loading' '--with-mod-script-pipe' '--with-wx-config=/usr/bin/wx-config' '--enable-static=yes' '--enable-shared=no' '--disable-programs' '--disable-sqlite' '--disable-external-libs' '--disable-alsa' '--disable-programs' '--disable-programs' 'PORTAUDIO_CFLAGS=-I/home/raz/Downloads/audacity-minsrc-2.3.1/build/../lib-src/portaudio-v19/include' 'PORTAUDIO_LIBS=/home/raz/Downloads/audacity-minsrc-2.3.1/build/../lib-src/portaudio-v19/lib/libportaudio.la' --cache-file=/dev/null --srcdir=../../../lib-src/libsoxr
../../../lib-src/libsoxr/configure: line 17: cmake: command not found
configure: error: ../../../lib-src/libsoxr/configure failed for lib-src/libsoxr
