Updated De-Clicker and new De-esser for speech
Try right click on the “DeClicker.ny” (in the first post), and select “Save As” (or whatever the equivalent is for your web browser).
When you’ve downloaded it, follow these instructions for how to install (and enable) a Nyquist plug-in: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html#nyquist_install
Hia all,
If I install DeClicker.ny on a Linux system, Manjaro Linux more specifically in Brazilian Portuguese language, what name would the plugin appear to me for example?
Noise removal? Or something different?
T+ = See you later
It will appear as “De-Clicker”. (It isn’t translated)
So I can’t install on Audacity 3.0.4, Linux Manjaro /usr/share/audacity/plug-ins
T+ = See you later
DeClicker.ny is a Nyquist plug-in. Install it with the Nyquist Plug-in Installer. See: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_linux.html#nyquist_install
Hi all.
I’ve read through this thread and see others have this issue but no resolution. I’ve downloaded .ny plugins before by moving them to Application Support/Audacity/Plugins…
so I’m pretty sure I know what I’m doing there.
However, I’ve tried to download the declicker plugin. As previously reported by others on this thread, my Mac asks me to choose an App to open it - when I open App store it says it’s not supported in the UK.
So, I dragged and dropped the Declicker plugin file to my desktop which seemed to work okay. I then moved it to ApplicationsSupport/Audacity/Plugins - I can see it’s there right next to ACX. However when I open Audacity it’s still not listed as a plugin in Effects>Add/New plugin.
If you look at my screenshot it says it’s a “text clipping” whereas ACX is a document.
There’s no other way to save declicker to my Mac other than dragging and dropping. If I click Save link as - it immediately goes back to the message asking to choose an app to open it.
Any ideas? Thanks so much.
Dawn
For current versions of Audacity, it is recommended to use the “Nyquist Plug-in Installer” rather than manually moving the .ny file.
For macOS, see here for how to install and enable Nyquist plug-ins: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_mac_os_x.html#nyquist_install
Thank you.
I already have the Nyquist installer listed in my Audacity plugins but can’t see how it works and the links don’t really explain - thanks
Just figured out how to use the plugin installer - now all sorted and it works fine. Thank you.
Just found the plugins. When I try to apply it to a large project it crashes Audacity.
I can only do 1 or 2 mins of audio at a time. Partial Crash Dump below.
Operating system: Windows NT
                  10.0.19044
CPU: amd64
     family 6 model 167 stepping 1
     16 CPUs
GPU: UNKNOWN
Crash reason:  EXCEPTION_ACCESS_VIOLATION_READ
Crash address: 0x1e7ecdda000
Process uptime: 193 seconds
Thread 0 (crashed)
 0  Audacity.exe + 0x61e6e0
    rax = 0x00000000b84cea26   rdx = 0x0000000000000780
    rcx = 0x0000000000000000   rbx = 0x000001e7e296dcf0
    rsi = 0x000001e7ecdda000   rdi = 0x000001e7e7501808
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd4f20
     r8 = 0x0000000000000780    r9 = 0x000001e7e75001f0
    r10 = 0x000001e7e296dcf0   r11 = 0x0000000000000780
    r12 = 0x000001e7fa1b15c8   r13 = 0x000001e7e7501ff0
    r14 = 0x00000000ffc5b507   r15 = 0x0000000000000b25
    rip = 0x00007ff71299e6e0
    Found by: given as instruction pointer in context
    Stack contents:
     0000003971dd4f20 f0 dc 96 e2 e7 01 00 00 00 00 00 00 00 00 00 00  ðܖâç...........
     0000003971dd4f30 48 dd 96 e2 e7 01 00 00 00 00 00 00 00 00 00 00  Hݖâç...........
     0000003971dd4f40 01 00 00 00 00 00 00 00 c8 ef 96 e2 e7 01 00 00  ........Èï–âç...
     0000003971dd4f50 9c 1b 41 e3 e7 01 00 00 e8 30 9d f5 e7 01 00 00  œ.Aãç...è0.õç...
     0000003971dd4f60 b8 cd 96 e2 e7 01 00 00 f0 2e 9d f5 e7 01 00 00  ¸Í–âç...ð..õç...
     0000003971dd4f70 44 85 1d fa e7 01 00 00 16 b5 97 12 f7 7f 00 00  D….úç....µ—.÷...
    Possible instruction pointers:
 1  Audacity.exe + 0x5fb516
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd4f80
    rip = 0x00007ff71297b516
    Found by: stack scanning
    Stack contents:
     0000003971dd4f80 30 e9 1a fa e7 01 00 00 f0 2e 9d f5 e7 01 00 00  0é.úç...ð..õç...
     0000003971dd4f90 f0 1f 50 e7 e7 01 00 00 f0 dc 96 e2 e7 01 00 00  ð.Pçç...ðܖâç...
     0000003971dd4fa0 00 00 00 00 00 00 00 00 8c 08 9d 12 f7 7f 00 00  ........Œ...÷...
 2  Audacity.exe + 0x65088c
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd4fb0
    rip = 0x00007ff7129d088c
    Stack contents:
     0000003971dd4fb0 58 ef 96 e2 e7 01 00 00 60 50 dd 71 39 00 00 00  Xï–âç...`PÝq9...
     0000003971dd4fc0 f8 03 00 00 00 00 00 00 80 bd 97 12 f7 7f 00 00  ø........½—.÷...
 3  Audacity.exe + 0x5fbd80
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd4fd0
    rip = 0x00007ff71297bd80
    Stack contents:
     0000003971dd4fd0 01 00 00 00 00 00 00 00 60 50 dd 71 39 00 00 00  ........`PÝq9...
     0000003971dd4fe0 68 3f 01 13 f7 7f 00 00                          h?..÷...
 4  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd4fe8
    rip = 0x00007ff713013f68
    Stack contents:
     0000003971dd4fe8 40 ce 96 e2 e7 01 00 00 e8 30 9d f5 e7 01 00 00  @Ζâç...è0.õç...
     0000003971dd4ff8 16 b5 97 12 f7 7f 00 00                          .µ—.÷...
 5  Audacity.exe + 0x5fb516
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5000
    Stack contents:
     0000003971dd5000 40 85 1d fa e7 01 00 00 58 ef 96 e2 e7 01 00 00  @….úç...Xï–âç...
     0000003971dd5010 02 00 00 00 00 00 00 00 68 3f 01 13 f7 7f 00 00  ........h?..÷...
 6  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5020
    Stack contents:
     0000003971dd5020 30 62 74 e2 e7 01 00 00 9e bd 99 12 f7 7f 00 00  0btâç...ž½..÷...
 7  Audacity.exe + 0x61bd9e
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5030
    rip = 0x00007ff71299bd9e
    Stack contents:
     0000003971dd5030 40 ce 96 e2 e7 01 00 00 68 3f 01 13 f7 7f 00 00  @Ζâç...h?..÷...
 8  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5040
    Stack contents:
     0000003971dd5040 68 c1 62 e7 e7 01 00 00 4f fb 97 12 f7 7f 00 00  hÁbçç...Oû—.÷...
 9  Audacity.exe + 0x5ffb4f
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5050
    rip = 0x00007ff71297fb4f
    Stack contents:
     0000003971dd5050 00 00 00 00 00 00 00 00 e6 6a 97 12 f7 7f 00 00  ........æj—.÷...
10  Audacity.exe + 0x5f6ae6
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5060
    rip = 0x00007ff712976ae6
    Stack contents:
     0000003971dd5060 f8 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ø...............
     0000003971dd5070 00 00 00 00 00 00 00 00 e2 03 98 12 f7 7f 00 00  ........â...÷...
11  Audacity.exe + 0x6003e2
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5080
    rip = 0x00007ff7129803e2
    Stack contents:
     0000003971dd5080 68 8b 70 e2 e7 01 00 00 e8 34 ba e2 e7 01 00 00  h‹pâç...è4ºâç...
     0000003971dd5090 68 3f 01 13 f7 7f 00 00                          h?..÷...
12  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5098
    Stack contents:
     0000003971dd5098 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd50a8 07 25 98 12 f7 7f 00 00                          .%..÷...
13  Audacity.exe + 0x602507
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd50b0
    rip = 0x00007ff712982507
    Stack contents:
     0000003971dd50b0 b0 7c 70 e2 e7 01 00 00 18 4d ba e2 e7 01 00 00  °|pâç....Mºâç...
     0000003971dd50c0 78 50 ba e2 e7 01 00 00 00 00 00 00 00 00 00 00  xPºâç...........
     0000003971dd50d0 40 c1 62 e7 e7 01 00 00 50 6a 97 12 f7 7f 00 00  @Ábçç...Pj—.÷...
14  Audacity.exe + 0x5f6a50
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd50e0
    rip = 0x00007ff712976a50
    Stack contents:
     0000003971dd50e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd50f0 08 c2 62 e7 e7 01 00 00 15 6d 97 12 f7 7f 00 00  .Âbçç....m—.÷...
15  Audacity.exe + 0x5f6d15
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5100
    rip = 0x00007ff712976d15
    Stack contents:
     0000003971dd5100 e0 73 70 e2 e7 01 00 00 20 36 ba e2 e7 01 00 00  àspâç... 6ºâç...
     0000003971dd5110 38 c1 62 e7 e7 01 00 00 01 00 00 00 00 00 00 00  8Ábçç...........
     0000003971dd5120 78 04 ce e2 e7 01 00 00 b5 0c 98 12 f7 7f 00 00  x.Îâç...µ...÷...
16  Audacity.exe + 0x600cb5
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5130
    rip = 0x00007ff712980cb5
    Stack contents:
     0000003971dd5130 a0 2f 70 e2 e7 01 00 00 d8 4d ba e2 e7 01 00 00   /pâç...ØMºâç...
     0000003971dd5140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5150 01 00 00 00 00 00 00 00 38 c1 62 e7 e7 01 00 00  ........8Ábçç...
     0000003971dd5160 01 00 00 00 39 00 00 00 00 00 00 00 00 00 00 00  ....9...........
     0000003971dd5170 30 51 dd 71 39 00 00 00 00 00 00 00 00 00 00 00  0QÝq9...........
     0000003971dd5180 30 51 dd 71 39 00 00 00 00 00 00 00 00 00 00 00  0QÝq9...........
     0000003971dd5190 78 04 ce e2 e7 01 00 00 01 00 00 00 00 00 00 00  x.Îâç...........
     0000003971dd51a0 68 3f 01 13 f7 7f 00 00                          h?..÷...
17  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd51a8
    Stack contents:
     0000003971dd51a8 9c 1b 41 e3 e7 01 00 00 38 c1 62 e7 e7 01 00 00  œ.Aãç...8Ábçç...
     0000003971dd51b8 01 00 00 00 00 00 00 00 5d 0c 98 12 f7 7f 00 00  ........]...÷...
18  Audacity.exe + 0x600c5d
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd51c8
    rip = 0x00007ff712980c5d
    Stack contents:
     0000003971dd51c8 a0 1f 00 00 7f 02 00 00 f6 28 5c 8f c2 4d 50 40   .......ö(\.ÂMP@
     0000003971dd51d8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd51e8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40  ...............@
     0000003971dd51f8 00 00 00 00 00 00 00 00 98 8e 15 d5 f3 90 c5 41  .........Ž.Õó.ÅA
     0000003971dd5208 00 00 00 00 00 00 00 00 cc f3 b0 c0 f0 71 9d 40  ........Ìó°Àðq.@
     0000003971dd5218 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5228 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5238 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5248 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5258 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5268 00 00 00 00 00 00 00 00 30 53 dd 71 39 00 00 00  ........0SÝq9...
     0000003971dd5278 b0 85 61 e7 e7 01 00 00 38 c1 62 e7 e7 01 00 00  °…açç...8Ábçç...
     0000003971dd5288 01 00 00 00 e7 01 00 00 18 c1 62 e7 e7 01 00 00  ....ç....Ábçç...
     0000003971dd5298 40 c1 62 e7 e7 01 00 00 58 08 eb e2 e7 01 00 00  @Ábçç...X.ëâç...
     0000003971dd52a8 d0 5d b9 e2 e7 01 00 00 00 00 00 00 00 00 00 00  Ð]¹âç...........
     0000003971dd52b8 f0 14 ba e2 e7 01 00 00 e5 20 6b b3 73 0b 00 00  ð.ºâç...å k³s...
     0000003971dd52c8 08 c2 62 e7 e7 01 00 00 01 00 00 00 00 00 00 00  .Âbçç...........
     0000003971dd52d8 6d 18 98 12 f7 7f 00 00                          m...÷...
19  Audacity.exe + 0x60186d
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd52e0
    rip = 0x00007ff71298186d
    Stack contents:
     0000003971dd52e0 00 00 00 00 00 00 00 00 78 04 ce e2 e7 01 00 00  ........x.Îâç...
     0000003971dd52f0 c8 c1 62 e7 e7 01 00 00 00 00 00 00 00 00 00 00  ÈÁbçç...........
     0000003971dd5300 01 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5310 78 04 ce e2 e7 01 00 00 38 c1 62 e7 e7 01 00 00  x.Îâç...8Ábçç...
     0000003971dd5320 c8 1f 85 e2 e7 01 00 00 42 0d 98 12 f7 7f 00 00  È.…âç...B...÷...
20  Audacity.exe + 0x600d42
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5330
    rip = 0x00007ff712980d42
    Stack contents:
     0000003971dd5330 02 00 00 00 e7 01 00 00 00 00 00 00 00 00 00 00  ....ç...........
     0000003971dd5340 e0 52 dd 71 39 00 00 00 78 04 ce e2 e7 01 00 00  àRÝq9...x.Îâç...
     0000003971dd5350 e0 52 dd 71 39 00 00 00 00 00 00 00 00 00 00 00  àRÝq9...........
     0000003971dd5360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5370 68 3f 01 13 f7 7f 00 00                          h?..÷...
21  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5378
    Stack contents:
     0000003971dd5378 9c 1b 41 e3 e7 01 00 00 68 3f 01 13 f7 7f 00 00  œ.Aãç...h?..÷...
22  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5388
    Stack contents:
     0000003971dd5388 28 db b9 e2 e7 01 00 00 1a 18 98 12 f7 7f 00 00  (Û¹âç.......÷...
23  Audacity.exe + 0x60181a
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5398
    rip = 0x00007ff71298181a
    Stack contents:
     0000003971dd5398 a0 1f 00 00 7f 02 00 00 f6 28 5c 8f c2 4d 50 40   .......ö(\.ÂMP@
     0000003971dd53a8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd53b8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40  ...............@
     0000003971dd53c8 00 00 00 00 00 00 00 00 98 8e 15 d5 f3 90 c5 41  .........Ž.Õó.ÅA
     0000003971dd53d8 00 00 00 00 00 00 00 00 cc f3 b0 c0 f0 71 9d 40  ........Ìó°Àðq.@
     0000003971dd53e8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd53f8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5408 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5418 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5428 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5438 00 00 00 00 00 00 00 00 e0 55 dd 71 39 00 00 00  ........àUÝq9...
     0000003971dd5448 b0 85 61 e7 e7 01 00 00 38 c1 62 e7 e7 01 00 00  °…açç...8Ábçç...
     0000003971dd5458 01 00 00 00 f7 7f 00 00 18 c1 62 e7 e7 01 00 00  ....÷....Ábçç...
     0000003971dd5468 40 c1 62 e7 e7 01 00 00 d0 08 eb e2 e7 01 00 00  @Ábçç...Ð.ëâç...
     0000003971dd5478 d0 5d b9 e2 e7 01 00 00 00 00 00 00 00 00 00 00  Ð]¹âç...........
     0000003971dd5488 f0 70 97 12 f7 7f 00 00                          ðp—.÷...
24  Audacity.exe + 0x5f70f0
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5490
    rip = 0x00007ff7129770f0
    Stack contents:
     0000003971dd5490 35 23 6b b3 73 0b 00 00 50 86 a6 e2 e7 01 00 00  5#k³s...P†¦âç...
     0000003971dd54a0 28 db b9 e2 e7 01 00 00 68 3f 01 13 f7 7f 00 00  (Û¹âç...h?..÷...
25  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd54b0
    Stack contents:
     0000003971dd54b0 00 00 00 00 00 00 00 00 50 6a 97 12 f7 7f 00 00  ........Pj—.÷...
26  Audacity.exe + 0x5f6a50
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd54c0
    Stack contents:
     0000003971dd54c0 18 c1 62 e7 e7 01 00 00 00 00 00 00 00 00 00 00  .Ábçç...........
     0000003971dd54d0 00 00 00 00 00 00 00 00 4f fb 97 12 f7 7f 00 00  ........Oû—.÷...
27  Audacity.exe + 0x5ffb4f
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd54e0
    Stack contents:
     0000003971dd54e0 88 08 eb e2 e7 01 00 00 a0 08 eb e2 e7 01 00 00  ..ëâç... .ëâç...
     0000003971dd54f0 68 3f 01 13 f7 7f 00 00                          h?..÷...
28  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd54f8
    Stack contents:
     0000003971dd54f8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5508 e2 03 98 12 f7 7f 00 00                          â...÷...
29  Audacity.exe + 0x6003e2
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5510
    Stack contents:
     0000003971dd5510 68 8b 70 e2 e7 01 00 00 c0 50 ba e2 e7 01 00 00  h‹pâç...ÀPºâç...
     0000003971dd5520 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5530 01 00 00 00 00 00 00 00 50 6a 97 12 f7 7f 00 00  ........Pj—.÷...
30  Audacity.exe + 0x5f6a50
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5540
    Stack contents:
     0000003971dd5540 b8 c0 62 e7 e7 01 00 00 d0 08 eb e2 e7 01 00 00  ¸Àbçç...Ð.ëâç...
     0000003971dd5550 00 09 eb e2 e7 01 00 00 18 09 eb e2 e7 01 00 00  .	ëâç....	ëâç...
     0000003971dd5560 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5570 68 3f 01 13 f7 7f 00 00                          h?..÷...
31  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5578
    Stack contents:
     0000003971dd5578 d8 59 ba e2 e7 01 00 00 d8 c0 62 e7 e7 01 00 00  ØYºâç...ØÀbçç...
     0000003971dd5588 be 6c 97 12 f7 7f 00 00                          ¾l—.÷...
32  Audacity.exe + 0x5f6cbe
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5590
    rip = 0x00007ff712976cbe
    Stack contents:
     0000003971dd5590 e0 73 70 e2 e7 01 00 00 30 53 ba e2 e7 01 00 00  àspâç...0Sºâç...
     0000003971dd55a0 00 00 00 00 00 00 00 00 90 56 dd 71 39 00 00 00  .........VÝq9...
     0000003971dd55b0 f0 56 b9 e2 e7 01 00 00 08 45 ba e2 e7 01 00 00  ðV¹âç....Eºâç...
     0000003971dd55c0 d8 59 ba e2 e7 01 00 00 58 f3 df e2 e7 01 00 00  ØYºâç...Xóßâç...
     0000003971dd55d0 d0 5d b9 e2 e7 01 00 00 00 00 00 00 00 00 00 00  Ð]¹âç...........
     0000003971dd55e0 02 00 00 00 00 00 00 00 d8 59 ba e2 e7 01 00 00  ........ØYºâç...
     0000003971dd55f0 90 55 dd 71 39 00 00 00 00 00 00 00 00 00 00 00  .UÝq9...........
     0000003971dd5600 90 55 dd 71 39 00 00 00 90 56 dd 71 39 00 00 00  .UÝq9....VÝq9...
     0000003971dd5610 d8 c0 62 e7 e7 01 00 00 d8 59 ba e2 e7 01 00 00  ØÀbçç...ØYºâç...
     0000003971dd5620 68 3f 01 13 f7 7f 00 00                          h?..÷...
33  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5628
    Stack contents:
     0000003971dd5628 9c 1b 41 e3 e7 01 00 00 68 3f 01 13 f7 7f 00 00  œ.Aãç...h?..÷...
34  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5638
    Stack contents:
     0000003971dd5638 28 db b9 e2 e7 01 00 00 83 6c 97 12 f7 7f 00 00  (Û¹âç...ƒl—.÷...
35  Audacity.exe + 0x5f6c83
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5648
    rip = 0x00007ff712976c83
    Stack contents:
     0000003971dd5648 a0 1f 00 00 7f 02 00 00 f6 28 5c 8f c2 4d 50 40   .......ö(\.ÂMP@
     0000003971dd5658 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5668 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40  ...............@
     0000003971dd5678 00 00 00 00 00 00 00 00 98 8e 15 d5 f3 90 c5 41  .........Ž.Õó.ÅA
     0000003971dd5688 00 00 00 00 00 00 00 00 cc f3 b0 c0 f0 71 9d 40  ........Ìó°Àðq.@
     0000003971dd5698 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd56a8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd56b8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd56c8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd56d8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd56e8 00 00 00 00 00 00 00 00 f0 57 dd 71 39 00 00 00  ........ðWÝq9...
     0000003971dd56f8 d8 85 61 e7 e7 01 00 00 b8 c0 62 e7 e7 01 00 00  ؅açç...¸Àbçç...
     0000003971dd5708 01 00 00 00 f7 7f 00 00 c0 c0 62 e7 e7 01 00 00  ....÷...ÀÀbçç...
     0000003971dd5718 f0 c0 62 e7 e7 01 00 00 78 09 eb e2 e7 01 00 00  ðÀbçç...x	ëâç...
     0000003971dd5728 d0 5d b9 e2 e7 01 00 00 00 00 00 00 00 00 00 00  Ð]¹âç...........
     0000003971dd5738 6f 6e 97 12 f7 7f 00 00                          on—.÷...
36  Audacity.exe + 0x5f6e6f
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5740
    rip = 0x00007ff712976e6f
    Stack contents:
     0000003971dd5740 45 24 6b b3 73 0b 00 00 00 00 00 00 00 00 00 00  E$k³s...........
     0000003971dd5750 03 00 00 00 00 00 00 00 d8 c0 62 e7 e7 01 00 00  ........ØÀbçç...
     0000003971dd5760 00 00 00 00 00 00 00 00 b3 69 97 12 f7 7f 00 00  ........³i—.÷...
37  Audacity.exe + 0x5f69b3
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5770
    rip = 0x00007ff7129769b3
    Stack contents:
     0000003971dd5770 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5780 f0 57 dd 71 39 00 00 00 00 00 00 00 00 00 00 00  ðWÝq9...........
     0000003971dd5790 f0 5c dd 71 39 00 00 00 66 0b 52 25 fe 7f 00 00  ð\Ýq9...f.R%þ...
38  ntdll.dll + 0x30b66
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd57a0
    rip = 0x00007ffe25520b66
    Stack contents:
     0000003971dd57a0 60 dc b9 e2 e7 01 00 00 00 00 00 00 00 00 00 00  `ܹâç...........
     0000003971dd57b0 03 00 00 00 00 00 00 00 b5 0c 98 12 f7 7f 00 00  ........µ...÷...
39  Audacity.exe + 0x600cb5
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd57c0
    Stack contents:
     0000003971dd57c0 f0 56 b9 e2 e7 01 00 00 e0 ce b9 e2 e7 01 00 00  ðV¹âç...àιâç...
     0000003971dd57d0 a8 c0 62 e7 e7 01 00 00 01 00 00 00 00 00 00 00  ¨Àbçç...........
     0000003971dd57e0 03 00 00 00 39 00 00 00 a8 c0 62 e7 e7 01 00 00  ....9...¨Àbçç...
     0000003971dd57f0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5800 c0 57 dd 71 39 00 00 00 a8 c0 62 e7 e7 01 00 00  ÀWÝq9...¨Àbçç...
     0000003971dd5810 c0 57 dd 71 39 00 00 00 01 00 00 00 00 00 00 00  ÀWÝq9...........
     0000003971dd5820 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
     0000003971dd5830 68 3f 01 13 f7 7f 00 00                          h?..÷...
40  Audacity.exe + 0xc93f68
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5838
    Stack contents:
     0000003971dd5838 9c 1b 41 e3 e7 01 00 00 60 dc b9 e2 e7 01 00 00  œ.Aãç...`ܹâç...
     0000003971dd5848 28 db b9 e2 e7 01 00 00 5d 0c 98 12 f7 7f 00 00  (Û¹âç...]...÷...
41  Audacity.exe + 0x600c5d
    rbp = 0xfffffffffffff880   rsp = 0x0000003971dd5858
Dude, thank you soo much for this!
The De-Clicker is an excellent plug-in that was exactly what I was looking for. I’m using a Blue Yeti condenser mic for voice overs for my channel and the problem with that mic is that it picks up absolutely every mouth click, slosh, lip smack and undesirable sound imaginable.
I kept all default settings as is except for the Sensitivity Threshold (db) which I dropped from 6.00 to 0.50. That did it. All clicks and other sounds removed. However if you make your sensitivity that severe I wouldn’t apply the De-clicker to the entire waveform, it will remove the D’s in your speech some of the time. It will also soften harsher T’s and P’s (which actually improved my audio). But absolutely no complaints. It saved me from trying to pinpoint waveforms and fading in or out over the clicks, which was hit or miss.
Thank you for this awesome app and making my life a whole lot easier. Kudos!!
Thank you Paul for posting this, it’s an amazing tool and it’s incredible that you released it for free. You rock! :metal:
For me, the default settings of the de-esser from the first post barely softened the esses. The overtones go up all the way to 17 kHz in my store-bought audio book and the default de-esser settings stop at 8 kHz already. Tuning the parameters a little (leaving most settings close to the default, just a higher upper frequency bound and a better dB threshold), the narrator very quickly sounds like they have a lisp.
For me, the plugin basically makes the narrator either have a speech impairment or else insufficiently filters the sharp S-sounds.
To be fair, this book was quite extreme and the first time (across maybe fifty books) that I wanted to manually edit the book. I imagine you’d usually just avoid this problem when recording.
What worked much better for this case was simply the built-in Effect → Low Pass Filter. The recording’s quality clearly decreases (e.g. if you use high dampening above 3kHz, it sounds like the narrator is reading to you personally over an old phone line :laughing:), but at least it doesn’t make the narrator sound speech-impaired. Depending on how much quality you’re willing to sacrifice to get softer esses, starting point values might be:
  • high de-essing (big quality difference): LPF 4000 Hz, 36 dB per octave rolloff
  • medium de-essing (medium quality difference): LPF 5000 Hz, 6 dB per octave rolloff
I’m not sure why Audacity doesn’t just allow you to set arbitrary rolloff (dB) values, but the defaults seem granular enough to be okay as well.
Related to narration: another helpful tool was the “compressor”. I was first trying to apply normalization but that apparently means something else in audio jargon. If the book has quiet whispers and loud screams (and you’re trying to listen while falling asleep, or in a noisy environment where you need to turn it up extremely high to hear the whispers) then this is definitely something you’ll want to check out.
Hope this helps someone! This will probably get buried in the middle of a soon-to-be 40-page topic but that’s just how it is. Maybe others can refer back to it if it was helpful for them.
The desibilator variant of Paul-L’s de-esser has 13kHz as the default.
If it’s causing lisping, back-off the threshold in 1dB steps until the lisp goes away.
[ If you have applied a de-esser, and it’s causing lisping,
you’ll have to undo the effect before trying again with different settings].
Hi there. My I use this de-clicker and de-esser for commercial purposes like editing voice overs and narration for clients?
Thank you.
Unfortunately Paul (the author of the plug-in) didn’t include any license information, but I’d assume that he intended the plug-in to be licensed the same as Audacity, which was GPL v2 at the time. GPL version 2 allows use for commercial purpose (GNU General Public License version 2 – Open Source Initiative)
Thank you
My dedicated proof-listener in LibriVox sent me a link to this forum and also a video that she said helped her to download and install the plug-in, but the video addresses Windows users, and I use an iMac. I encountered two mysteries.
First, the plug-ins that you offer are represented as having .ny suffixes, but the files that download have .php suffixes. When I use the Audacity plug-in installer, it returns an error message: “‘Audacity de-clicker.php’ is not a valid Nyquist plug-in.”
Second, somewhere I learned that plug-ins for Audacity are stored in a file whose path begins “/Audacity.app/Contents/ . . .” but the only place where I find “/Audacity.app” is the Applications folder, and that path extends no further than that.
Since the Audacity User Manual says nothing about installing plug-ins on a Mac except to use the plug-in installer, I must need some other kind of help.
You’ve got the wrong file. The Nyquist plug-in does have a “.ny” extension.
