SSM2019 monolithic pre-amp chip
Absolutely. With a balanced input signal, you have a voltage differential - the voltage on each line is referenced to the voltage on the other - a kind of push/pull relationship.
Ohms law I=V/R
The same thing applies to AC. The current is inversely proportional to the impedance, so for a given voltage differential the current through each wire will be inversely proportional to the impedance of its input. As you say, they must be balanced.
Regarding the overall input impedance, SM57’s (and 58’s and quite a lot of other dynamic microphones) tend to “overshoot” in their high frequency response unless there is a sufficiently low impedance load (around 500 - 600 Ohms) producing a harsh peak in the high frequency response. If the impedance is taken too low, then the low frequencies begin to roll off. The “sweet spot” for SM57s is around 500 to 600 Ohms.
Just to let you know that I finally got myself an SSM2019 chip and now I just need to find some time and patience to do something interesting with it :slight_smile:
Two problems you’ll probably hit right away are power supply rejection and environment noise.
Microphone signals are reeeely tiny and the power supplies are probably ideally +/- 15 volts, filtered very well. If there’s -60dB power supply ripple and trash and the chip has a power supply rejection ratio of -60, then the internal trash is at -120. If the microphone signal is -70dB (not uncommon with somebody playing classical guitar in a stair well) then the trash in the show is only -50. The numbers add up the wrong way and they do it quickly.
The other thing that will kill you is the inability to test unless the cabinet is closed. Microphone amplifiers will not work outside of their metal shell. I have a pix of one I built here somewhere…
Power supply is probably the most important piece of equipment in any signal sensitive application such as audio… That’s why I also got a bunch of high quality panasonic fc series capacitors… :slight_smile:
I still need to get a decent transformer… (which will probably be the most expensive part of the party)
I know.
http://www.kozco.com/tech/pix/MicAmp2.jpg
The big silver transformer in the back isn’t the power transformer. That’s the output transformer. It will do +24dBm into 600 ohms at any audible frequency. With suitable cables, you can probably weld metal with it.
The power transformer is the little orange thing hiding under the regulators up-left. It’s a toroid, chosen because they don’t radiate. They just don’t have external 60Hz fields. I put the mains transformer inside the cabinet for which I should probably be locked up, but I don’t have hum problems.
This is just before I finished the final wiring and I hadn’t tested it yet. It turned out to have terrible frequency response due to some poor choices in the preamp stage.
The two red lights were supposed to be stage clipping indicators. Never designed or connected. The green power light was a surprisingly difficult problem. Remember the two supplies are +/- 15 volts. You can’t put the light between them because if you lose one supply, the leakage in the dead one will keep the light lit. Two green lights would be admitting defeat.
I put a constant current device and a zener diode in with the LED. The LED will not light at 20 volts, but is perfectly happy at 30.
It did have one unexpected attribute. It turns off exactly like a tube amplifier. Pull the plug and the class-A FET preamplifier gain slowly fades and the sound finally turns crunchy and stops. If I had thought of it, I would totally have designed that in.
I was thinking about getting a +/- 18V power supply, but I need to read the datasheets again, to be sure of the tensions I will need…
I made my components list a few months ago and I’ve completely forgot why I chose it that way then…
I think the +/- 18V was to be able to achieve 48Vdc (18Vac * 2 * sqrt(2) ~= 51Vdc after rectification).
Three volts is right on the edge of not having enough difference for a voltage regulator – assuming you use a packaged one, and it may have problems with normal mains variations – it works between breakfast and lunch, but not between dinner and bedtime. Maybe a passive regulator, a resistor feeding a shunt zener, heavily filtered. It doesn’t need to be much and it doesn’t have to be perfectly stable. It’s re-regulated inside the microphone. It can’t be super critical because it has to survive any length of microphone cable.
Phantom is an interesting design problem. You will need carefully matched resistors to inject the voltage and that may be expensive. You also can’t turn the voltage on and off without special consideration. That collapsing tension will go through the electronics like a nuclear blast. There is a protection circuit I need to find…
My supplies are both pre-packaged 15 volt units. Bypassed with mylar film .1ufd in and out, plus the large aluminum filter cap at the input. I put the diode front to back to absolutely avoid any reverse voltage. One of the two regulators, I think the negative one, demands the mylar caps for stability, so I put them on both. I did a sound check on the voltages and the ripple is in the -65 or better range.
The transformers are both Jensen. The input is a JT-115K-E60 with double shielding.
http://www.jensen-transformers.com/mic_in.html
If you can’t be compulsive, life just isn’t worth living. I assume your chip matches the output impedance of the microphone with no transformer. That’s the holy grail of microphone amplifiers. So no input coil for you.
What are you going to follow the chip with? Generally, you can only get about 60dB of gain and the sound channel needs at least another 10 or 15 to be comfortable. Also, you may not want to run the chip at maximum gain all the time.
I have two portable mixers that only have 60dB gain, total, and they all run out. The knob hits maximum and I would kill to get a little more.
https://forum.audacityteam.org/t/firebox-or-inspire/174/1
This is a write-up on phantom power regulation. They bring up a good point. The phantom power supply can’t be connected to anything else…
http://sound.westhost.com/project96.htm
Thanks guys. I’m using hand-matched .1% 6k8 resistors…
That’s for the phantom injection into the microphone line. An mismatch kills the microphone’s ability to reject cable generated interference. You don’t want to start listening to Terra Nova on your mic amplifier.
assuming that you actually need 48 V.
If Bruno is building this for a specific microphone he may not need the full 48V, (and certainly will not need 200mA for a single microphone. (AKG C1000S is specified for phantom power in the range of 9 to 52 V, 2 mA)
Depends on what the design center is. If he wants it for any microphone, then he needs to at least get close.
Thanks for all the comments Koz. I haven’t started thinking about it yet… I had some ideas a few monthes ago, which I didn’t write down and that I have forgotten by now… :slight_smile:
I will have to start searching again, read the datasheets, googling, etc…
My main goal is to build an amp for my large diaphragm t-bone mic. First something simple to connect to my soundcard analog input, and if it goes well later I’ll think about building an usb interface…
I also have another project, which is to try to find a way to hack and improve the t-bone micplug I bought… I have no idea yet if this two projects will get together at some point or not…
I wanted to get a pair of 0.1% resistors too but it was out of stock on digi-key, so I couldn’t add it to this order… I’ll try the local stores and if I’m unlucky I’ll add it to the next online order (maybe next order will be on farnell and they probably have it). I also need to check how much current I need to choose the proper transformer. But right now I’m quite busy with other things and I probably won’t have time to look into that before xmas…
If you get a pack or resistors, there’s a good chance that there will be a matching pair. If you have a reasonable multimeter, testing is very easy. If not, there’s the old Wheatstone Bridge method. http://sound.westhost.com/project96.htm#appendix
If you don’t mind taking up a bit more board space, a pack of (E24) 5% 5.6k, a pack of 5% 1.2k resistors have a good chance of producing a very close match.
E48 series resistors are rated at 2% and reasonably inexpensive and are available as 6.81k - you would just need to find a pair that are within about 10 ohms of each other.
CPC Farnell do a 6.8k 1% resistor for under 1 Euro (£0.53 GBP) for a pack of 50.
I thought of that too… Not sure about the reasonable multimeter… I have a cheap one made in china hehe :stuck_out_tongue: That’s why I had thought about the wheatstone bridge method too :slight_smile:
I think I saw those at digi-key too… but 1% and 2% are not 0.1% either hehe (though the chances of getting 2 matching ones are closer…)
The guys at the local store I usually go are very nice so I might ask them to let me check some at the store with one of their reasonable multimeters hehe :smiley:
Not if you like them and want them to like you. That’s serious drudge work. You don’t know which two are going to come out, so you have to record each reading and then go back through the close ones to make sure you didn’t make an error, eventually producing the hero pair. A good digital multi-meter or actual bridge.
And given where these are in the circuit, you need the lowest noise composition you can get in addition to matching.
Metal Film? Carbon Film? I forget which material has the least noise, but start there. Cheap carbon composition is laughably noisy and unstable with temperature.
I pulled down the data sheet. It looks like a very nice amplifier. Top quality noise specification, frequency response, etc.
However. They don’t mention gain trim in the sheet. You can’t run the thing at 60dB gain all the time. That’s an invitation to input overloading and clipping. The chip I used (THAT 1512) attempted to deal with this by giving designs for gain trim by either a variable resistor or gain resistor switching – none particularly graceful, but they reflect what’s done in modern amplifiers.
http://www.thatcorp.com/1510-1512_Audio_Preamplifier_ICs.shtml
They also talk about using Shottky Barrier diodes as protection…
we recommended using Schottky diodes ( 1N5819 types) at D 1 ~ D4 to protect the 1510/1512 inputs against overloads. …
Oh, and I can tell you 60dB makes any imbalance at all shut the amplifier down, and the obvious solution of trimming the “Reference” input doesn’t work beyond a very gentle trim to make up for slight product imbalances.
How do you tell if you’re clipping? That’s another design problem on the back burner. Aaaaany minute now I’m going to get to that.
I don’t know yet how much gain I will need… maybe 40dB wiil be enough.
That’s almost certainly not true. Refer to my review of the Shure X2U…
That device only has one control for volume in the sound channel similar to the other device I have, the Sound Device MixPre…
http://www.sounddevices.com/products/mx2master.htm
Both of them max out at 60dB, and both of them get blown away with the simple, cheap Peavey PV6…
http://www.sweetwater.com/store/detail/PV6
…which has three controls for each microphone: trimmer, channel fader, and master fader. It also has more gain and the ability to control it effectively, unlike the other two. Yes, I clearly understand the Peavey is not portable and the other two are.
My home-made unit had an interesting gain line-up. The transformer was good for 20, the amplifier was good for 20 and then I put a master amplifier and line driver good for 30. 70 total. That part worked, although I still expect to have overload problems.
I didn’t think it was important to have serious control over the gain until the first time I had to record a Real Announcer/Presenter/Voice Talent and deal with his expressive presentation.
“Can we take that last again? You’re fine. I need to make an adjustment…”
You are going to run into expression problems, too, given your microphone and theatrical playing.
