I’m sorry to say that, using the command line in the terminal, the problem still occurs, also when working on other projects on a different machine. Maybe it has something to do with the fact that the project’s length is 2 1/2 hours long?
Are you still receiving underruns in the Terminal?
If so you can go higher, such as:
env PULSE_LATENCY_MSEC=300 audacity
This is the first time I ran audacity. I got a buffer underrun here.
env PULSE_LATENCY_MSEC=100 audacity
(process:9932): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(process:9932): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(process:9932): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(process:9932): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
bt_audio_service_open: connect() failed: Verbinding is geweigerd (111)
Cannot connect to server socket err = Bestand of map bestaat niet
Cannot connect to server request channel
jack server is not running or cannot be started
no more csLADSPA plugins
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1904
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2171
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2840
ALSA lib pcm.c:7843:(snd_pcm_recover) underrun occurred
The second time no buffer underrun, but still I got the static pops and clicks.
(process:10133): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(process:10133): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(process:10133): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(process:10133): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
Please try a higher MSEC number as suggested.
