newbie seeks recommendations
Justa beach? I’m shootin’ for the whole island! (In my dreams anyway. :smiley: )
As I recall, my problem was simply that when I plugged in the ACX numbers to everything, I couldn’t get all three of them past the ACX Check at the same time. And every time I changed one number so I could get it past ACX Check, one of the other two numbers would then fail ACX Check. What finally saved me was that, through experimentation, I found what was for me the “magic” number in RMS Normalizer that always kept all three numbers passing ACX Check. Once in a while, after I had done some hand-mastering (all those “s” sounds and hard consonants) one of my ACX numbers would change to failing ACX Check, but I found that all I had to do to get it back to passing ACX Check was to re-apply the Normalizer --if it was on -3.5 I just changed it to -3.6; if it was already on -3.6, I changed it to -3.5. That worked every time but once (I was trying to get something shouty past ACX Check --I found that all I had to do that one time was to again apply RMS Normalizer).
Here’s what I did. I don’t understand why it always worked for me, but it did.
  1. Get Noise Profile, apply
  2. Apply your Notch Filter
  3. Apply your Low Rollout for Speech
  4. Apply a bit of Treble Cut
  5. Apply a bit of Base Boost
  6. Apply RMS Normalizer set on -19.90
  7. Apply Limiter
https://www.amazon.com/Hilarious-Dead-Guys-Chance-Undies/dp/B07K2K6JVQ/ref=tmm_aud_swatch_0?_encoding=UTF8&qid=&sr=
Once again, I thank you for your generous help. BTW, just in case you are interested, here’s the email they send:
"Congratulations!
The Hilarious Dead Guy’s Last Chance Undies is now on sale at Audible, and it will be available on iTunes and Amazon within the next few days. Once you begin earning royalties on your audiobook, you will be able to monitor its sales on ACX. Simply log into ACX and go to the Completed Projects tab. From there, you will be able to see your sales grow. Don’t forget to confirm that your bank information is up-to-date and accurate to receive payments.
To support your audiobook marketing efforts, ACX will provide you with 25 promotional codes for your Audible marketplace (US or UK) upon request. If you are under an exclusive contract with ACX and in good standing, please email support@acx.com. Your request will be reviewed within 5 business days. Learn more.
Ready to earn? Check out these tips on how to best promote your audiobook and how you can capitalize on the ACX Bounty Referral program, which gets you up to $75 each and every time your audiobook is the first purchase by a new Audible member using unique links located in your Project Dashboard.
Be sure to bookmark our Help Center for answers to your questions as they come up.
We can’t wait to hear your audiobook.
The ACX Team"
That’s from a joke I had where your goal is to read audiobooks, make tons of money and retire to a nice cottage somewhere on French Rivera, say Côte d’Azur, Coq au Vin or Mal de Mer.
I don’t need the whole island.
You should know that there’s a simple error that can cause you to fail ACX Check. The check needs at least 3/4 second of clean, perfect room tone (background noise) somewhere in the clip or it will fail your noise test. Sometimes badly. It’s very common to make noises during pauses in the performance, either taking a deep breath or shuffling your chair to get more comfortable. Anything like that will cause you to fail noise—even though the rest of the performance is perfect. The background noise has to be continuous and long enough for ACX Check to chew on it—at least 3/4 second.
Oh, and you are cautioned against “making” background sound by Generate > Silence. That gives an obviously bogus sound and ACX Check will pass too good.
“Sorry, that noise level is impossible. What are you up to?”
Your Amazon preview sounds different from others: it’s like a skype telephone-call , (no voice signal above 6kHz).
The other Amazon previews have voice up to 10kHz , (most people can hear up to ~14kHz) …
A possible explanation : your notch filter to deal with sibilance (“s” sounds) has amputated everything above 6kHz.
If that’s the case you need a De-Esser instead of a notch-filter.
An easy to use De-Esser plugin for which works with Audacity on Windows be had for less than US$5.
A slightly better De-Esser plugin can be had for free for 30 days only.
Thank you. I’ll look into that.
