Sorry, skipped a bit, trying to concentrate on one or two test cases.
I quit Audacity between most tests, but not in all tests.
That is the correct length. When imported in Audacity 2.1.1 alpha on my system, it’s zero seconds, according to the numbers below the wave form. It plays in under a second. Pic:
Log from this session:
16:11:19: Audacity 2.1.1-alpha-May 5 2015
16:11:19: Error: dlopen(.bundle, 2): image not found
16:11:20: Trying to load FFmpeg libraries...
16:11:20: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
16:11:20: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
16:11:20: avformat not monolithic
16:11:20: Loading avutil from '/Library/Application Support/audacity/libs/./libavutil.52.dylib'.
16:11:20: Loading avcodec from '/Library/Application Support/audacity/libs/./libavcodec.55.dylib'.
16:11:20: Loading avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
16:11:20: Actual avutil path /Library/Application Support/audacity/libs/./libavutil.52.dylib
16:11:20: Actual avcodec path /Library/Application Support/audacity/libs/./libavcodec.55.dylib
16:11:20: Actual avformat path /Library/Application Support/audacity/libs/libavformat.55.dylib
16:11:20: Importing symbols...
16:11:20: All symbols loaded successfully. Initializing the library.
16:11:20: Retrieving FFmpeg library version numbers:
16:11:20: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
16:11:20: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
16:11:20: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
16:11:20: FFmpeg libraries loaded successfully.
16:11:47: File name is /Users/wim/Desktop/Test files audio & video/TEST.TOOL.Ac3 Dolby Digital 5.1Ch Sound Test.avi
16:11:47: Mime type is *
16:11:47: Opening with libsndfile
16:11:47: Opening with liboggvorbis
16:11:47: Opening with libflac
16:11:47: Opening with libmad
16:11:47: Open(/Users/wim/Desktop/Test files audio & video/TEST.TOOL.Ac3 Dolby Digital 5.1Ch Sound Test.avi) succeeded
That’s with all the misbehaving files. MP3, wav and any other AUDIO file works. I haven’t been able to find any VIDEO file that imports audio into Audacity.
It’s not really a biggy, I never import video files into Audacity that way. It’s just that I’m baffled, since there doesn’t seem to be anything wrong with these files. And some of them I’ve been using as test files for a very long time.
And Audacity 2.1.0 and 2.1.1. alpha seem to be very well behaved on my system. I haven’t really turned up any problem in testing, apart from a very minor graphical glitch…
Could something like Flip4Mac interfere with ffmpeg or lame?
