Microhpone advice needed: Blue/Yeti vs Rode NT-USB
Even with ElectroBOOM’s “How To” videos? He has a knack for making mistakes. :laughing:
One of these may be useful if you’re still looking (Blue Yeti is in the list but some of the others might be an option!).
[Advertising is not permitted]
There are hundreds of blog sites about “The best 10 ”. It is not really helpful to link to them. Better to give your own personal review of the microphones that you have used.
I did find a place where No Editing is handy. There is a plumbing show where the performer, for example, replaces a faucet valve and makes all the home-newby mistakes. “I tried extracting the old one by hand, but it wouldn’t come out and I ended up using the little adapter they send with the kit.”
Yes, do put a towel down so the screw you dropped doesn’t go to the city sewer system.
Please do not plagiarise.
I’d still like to hear what koz is using…
So would I. I thought I knew where it was. Good thing I don’t need it in a hurry.
:wink:
