Just to say hello
Re Mic wont work…
Thanks to steve for mentioning the search box, and thanks to jademan for direction to the magnifying glass
to look for, all is back working again , thank you both for your input. davday
Hi Steve,
have a backing track that fills the screen, when played to the end it go’s back to the beginning
including click track. have tried to extend the track by reading the manual, but cannot get it right.
I just want to double the length of the existing track, but still retain the same sound.
Thanks in advance. Daveday
Hi Steve,
Would be most grateful if you can confirm am I posting correctly,
and where do I look for replies on the forum page to relate to last post made.
Thanks in advance.
Davday.
Your posts are fine except this thread is now multiple pages and it might be time to start a new topic. It also helps if your topic/title relates to the actual post. (A title of “hello” might get ignored.)
Of course it can’t sound the same unless you duplicate (repeat/loop) it. Or, you can cut the tempo in half while maintaining pitch but it probably won’t sound “natural”.
Just a quick Thank You to DVD doug for reading and answering my post this morning will try
your looping answer. It just go’s to show how good forums are in helping with peoples problems.
Davday.
Hi to Steve and admin,
Have had 3 Midi files posted into my email box ( vidio + hand written notes ) can I put them
into Audacity, if not what app should I be looking at. Thanks in advance.
Davday.
If you just want to play the MIDI files, Audacity should be able to do that, though there are better MIDI players. What happens if you download the files to your computer, then, after virus scanning them, double click to open the file in the default application?
