Finding the right equalization for my voice
I’m wondering if it’s because my voice tone is lower, and is resonating with the speakers more.
I think we’re traveling down the road of sound concepts.
Speakers the size of Kennedy Half-Dollars do not do low voices or bass sounds in general. If your whole world is based on personal sound systems, or better, your whole audience’s world, then yes, having a lower voice is a problem. I used to use a benchmark of being able to pick up your whole sound system with one hand. If you could do that, it was probably not so good to judge a wide variety of sound systems.
I’m using a stereo theater sound system and I can hear things that other people miss, just based on my being able to hear all parts of the sound experience.
That better? I created an equalization curve that left everything alone from 3000 and up and gently rolled off the bass notes.
I generated that curve based on your natural voice pitch and volume going up the same amount I brought it down. It should sound clear and clean with no odd peaks or resonances. If it makes it through your speaker test, but still seems too extreme, I can try another, less powerful curve and see if you like that.
Not everybody makes it through this. Voices have personalities. Mine will go through soundproof walls. Ian’s voice (from another post) causes one of my speakers to buzz. Only him.
I don’t have the exact name for the speakers but hardware is Realtek HD Audio
The one thing that’s common in three forum chapters struggle is those speakers.
How do they connect? Can you point to a web page that describes them? Do they plug into the wall for power? Do they get their juice from the USB plug?
Take a picture and include something like a pen or pencil for scale.
So far multiple people have commented on your pleasant voice and it sounds terrific in your headphones.
What’s wrong with this picture?
First, let me thank you again for all the help. Second, the editing you did on that sound clip seems to have gotten rid of most of bass speaker distortion, but the audio still sounds kind of strange. Hollow, sort of like I’m talking through a radio/walkie talkie or skype call, rather than just hearing my voice.
Oh I should have probably explained, the speakers I am listening through are a part of the computer :smiley: My bad. Low quality I know, but hear me out:
Let me give you another example. These guys have a random talk show where they talk about random things, and their voices sound fine through my speakers. https://www.youtube.com/watch?v=ICI9iY1_d7I
Admittedly, their voice tones are higher than mine which may be one of the reasons why there is no distortion. MY voice by contrast through the same speakers has the strange distortion, either catching too much of my voice and generating distortion that way, or sounding sort of hollow like I explained above.
If the speakers you have don’t have the same problem mine are having, I’ll assume it’s because yours are probably higher quality and can handle a better range of sound. If that’s the case, then I’ll assume that I just need better speakers and will continue to edit the audio the way I have been with your suggestions/improvements.
PS: Sorry for the late post, was busy on Sunday. Also apologies for sort of going around in circles with this issue. I’m trying to think of a better way to explain the problem, but I’m having a hard time putting the thought into words.
We also violated a rule. You’re on Windows, right? Win7? Win8? It’s good you choose those words. Windows likes to help you with built-in effects and processing. They can sound “weird” and “hollow”. I got to mess with a new PC at work and I couldn’t make it pass any sound tests. Turns out they left a “cathedral sound” playback filter running on it and didn’t tell me. Does your voice sound like Notre Dame? Chartres?
http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#enhancements
Do you leave Skype running in the background? That can cause problems.
I’m currently using the Windows 8.1 OS. I don’t believe my voice sounds like that type of hollow. That was a bad word for me to use, I apologize. I would point it more towards the speaking through a radio, walkie talkie effect more than the hollow cathedral effect. Not the crackling/popping walkie talkie effect, the actual voice quality (eg: the voice quality is reduced when talking through a walkie talkie to someone else)
Yes, I do leave Skype on in the background. If that causes problems, I will close it down. However, I was thinking of maybe doing a collaboration with a friend over Skype. Would that be an issue? Should I find a different program to use for that?
Finally, I wanted to give a bit of good news. I just got a mic stand, and it seems to have substantially reduced the amount of background noise I get from a raw recording. My guess is that the Blue Yeti base stand the mic came with was getting some vibrations through the desk I was using. The new stand seems to have mostly eliminated that. It’s also possible that it has improved on the above problem, but that might just be all the tips you’ve been giving me :slight_smile:
I’m very happy with all the progress I’ve been making with improving my sound quality. I kind of want to do a freeze frame jump sequence right now :smiley:
Yes. Audacity doesn’t always work well with Skype. Skype likes to take over the sound services in your machine and it doesn’t much care whatever else is going on. It’s very common to only be able to record one Skype voice and not the other.
I thought I had notes on Skype software programs. Pamela can do that.
http://www.pamela.biz/en/products/
Looking,
Here it is.
So Pamela is an add on that ensures all voices are recorded? Sorry, I’d just like to know a little more about the program so I understand why I should use it.
On a side note: I did some recording and audio editing and with the addition of the mic stand, your editing tips, and some experimentation of my own, I’ve sort of fixed the problem. The distortion is still there, but it’s less, which is good. If I prioritize headphones over computer speakers, I should be okay.
The upper two Pamela licenses will give you two separate, high quality WAV files featuring you on one track and the far side on the other. Perfect for individual filtering and adjusting as needed before melting them into one show. It answers the question: “The far side voice sucks. How do I split it off and fix it?” Usually with other software, you don’t.
Some packages only work with MP3 files. MP3 files get worse and worse quality as you edit and filter them and you can’t stop it. That’s just how MP3 works.
Some packages only give you one mixed track. If you need to apply a correction to just the far side, good luck with that.
By the way, if everybody is wearing headphones during the show, the Skype quality can be terrific.
Does she sound like she’s four time zones away from me?
http://kozco.com/tech/audacity/clips/DeniseFirstPass-Edited.mp3
I didn’t do this in software. I did with two computers and a sound mixer. It’s a first pass and it still had problems.
Her voice doesn’t sound terrible, but I can tell that it’s probably coming through some program. Other than that it all sounded pretty nice. Maybe needs a bit of background noise reduction.
I’ll check out Pamela and see if I need it.
I think this is the last post I’ll make here for a while. I’ll come back when I’ve figured out how to do collaborations. Thanks for all your help!
It’s coming through her MacBook Air built-in microphone and I think she was ironing a shirt at the time. No attempt at theatrical purity.
Yes, do post back if you get something to work. I think we had one person post back that they had troubles with Pamela and it turned out they made some silly mistake which we cleared immediately.
That’s not to say you can’t make this work on one computer with no special software. People do.
This is Chase’s podcast with his brother in another state. It sounds remarkably good and all he did was plug everything together, turn it all on and start podcasting. He is a digital celebrity. Most people go straight into the mud when they try this. Chase is looking at us like we’re all crazy.
Dude, you got nuclear-level lucky.
