So it is looking more and more like Audacity will not work as a volume recorder for me
The first link is a device for sale that dose not give a price or an online price to buy and the second link is only for apple software and will not run on my windows (IBM based) computer
If you look around (example: Amazon) you can find SPL meters from under $20, but don’t expect a cheap one to be very accurate, or be able to measure low level sound.
For a “Class 1” calibrated SPL meter, you could be paying well over $3000.
That’s the one you use if someone is suing your company for hearing damage. That’s also the one you use when you’re setting up a new screening room for clients writing big checks.
Well to be honest it was nothing spectacular then all that. I needed it to read about 100-130 db (or in 20 microns as you called it under your program)
A lot of those apps that will not run on win O/S (IBM base) only go upto 80-96 db, so not a lot of good there
I know I’m late to the party, but as I found this thread looking for more specific dB measurement tools and saw this common confusion, I thought I’d chime in for future stumblers-upon.
The difficulty in understanding the excellent descriptions above, I think, is that people are missing the part about speakers.
Audacity, and indeed any audio editing program, has no idea what speakers you have, let alone those of another person listening on their device. It also has no idea what volume you’ve set your speakers to.
Audio files do not actually tell a speaker how loud to be. They tell it how loud to be as a percent/fraction of the speaker’s maximum output. (The speaker volume control reduces that maximum value to whatever.)
For a single track, this is easy to understand: top of the meter is blasting at max, bottom is silent.
It gets messy when you have multiple tracks, because each track is literally added (math) together at each moment in time. But the output is still a fraction of the instruction “maximum output”. So the dB scale was created to express a measurement of relative power output. The wisdom in expressing it as negative values from a maximum of 0 makes perfect sense for them math and engineers, but is of debatable quality for newbies. But if you think about it as “reducing from maximum”, you can develop a more intuitive understanding of what you’re seeing.
