Try reading Auto Duck
Trust me - it’s been open for 2 weeks!
OK, by copying and pasting my Music track into a new project, then recording a small spoken text into the track below the music track, then selecting Autoduck, it worked!
That’s the good news. Now my challenge is that, in the course of about 30 minutes of Music track, I want 3 or 4 spoken bits, not contiguous, which the upper Music track should “duck” each time.
I can Undo the Autoduck that I just tested above. Then record and position the subsequent bits in the voice track. Then select Autoduck. By doing this, I assume the music track will Duck each time it sees a signal in the track below, but come back up (cease ducking) when that part of the voice track (which I suppose is the Control Track) is silent.
2 questions - 1) Will the AutoDuck work that way on multiple but non-contiguous signals in the Control Track? and 2) Is there an easier (more elegant) way to achieve what I’m trying to accomplish?
3rd question - I want to insert some “ads” into the Music track. I know I can split the track and shift the rest to the right to make room for the ads. I assume this will cause no problem to any Ducks that have already occured. (Yeah, I know the implications of “assume”…)
What I envision happening is that any Ducks “downstream” from the insertions will stay but no longer be lined up with the material on the Control track that they are ducking. If true, that can be fixed by repositioning the material on the Control track below the already-in-place Ducks.
If I’ve got all this correct, then with the Music track containing all the material it needs (music and ads and Ducks), and the Control track (directly below the Music track and containing only those (in my case) spoken bits that the Music track has ducked, all I have to do is select the two tracks (Music and Control), select , and I will have a new, single stereo track containing all the material for my 30 minute intro.
The last step would be to select that track and export it as a .mp3 for the guy in the sound booth to play at the appropriate time.
(Ok that’s not really the last step - I have 2 more 20 minute segments to do the same things to - and the real “last step” will have me enjoying a beverage of my choice!) (And it will be raised in salute to all here who have helped me! Many thanks.)
Roger
