Dear all,
For some reason Timer Record doesn't stop recording at the Recording End time or when I click the stop button prior to the End time. Can somebody help to solve this issue?
This is what happens:
1) When I hit on the stop button int the Audacity Timer Record Progress Panel, prior to the end time, everything freezes but recording keeps playing. I have to force quit the computer and restart after which I get a message to recover the file.
2) In the case I let the Timer Record run until the Recording End, in my case after 8 hours, it actually continues to record and the Audacity Timer Record Progress Panel as well and pretends as if the remaining time to record is still almost 8 hours and the recording just started. I have to force quit again and in one case the recovered file showed no sound at all.
Instead of recording for 8 hours I just tested 5 minutes. Both Elapsed en Remaining Time in the Timer Record Progress Panel show 00:00:00. It keeps on recording past the 5 minutes and can't do anything to stop except to force quit.
Thanks in advance for your help!
Devices/Software Used:
- Macbook Pro (early 2008) - 177GB free storage - I'm using this old Mac only for Audacity so there are no other applications
- Presonus USB audiobox
- Mac OS X 10.7.5 (Not possible to upgrade to later versions)
- Audacity 2.1.2
