I am using Audacity 2.02 and OS X 10.8.2. I don’t know how I installed audacity - whats is the dmg or zip?
I have successfully uploaded about 10 audio tapes. Each recording had two tracks appearing after I hit the record button. i.e a slightly different blue squiggly line in each track. I assume that the top track represent whats coming out the left speaker and the bottom track whats coming our of the right speaker. Is this correct?
Yesterday I was uploading and I am getting one blue squiggly blue line in the top track and a flat blue line in the bottom track. Is this an unbalanced stereo recording? If it is what do I do to correct the problem and if it isn’t can you tell me whats happening.
I checked Why I get an unbalanced stereo recording in FAQ and recording input channel is set to 2 (stereo), connections are OK and in applications - Utilities - Audio-MIDI Setup - audio Devices I had is set on the USB.
It also states I can correct the problem later using the Normalize effect - where is the Track control Panel?
Indeed correct - see this page in the manual: Audacity Manual
It’s either a dead right channel on your kit or leads - or possibly you have got Audacity set to record in momo rather than stereo. See this page in the manual: Audacity Manual
You can only correct for having one channel stronger than the other with the Normalize tool - it won’t work when one channel is dead.
I went and bought a new cable and the problem still persists. So I might have a dead channel in my kit. How do you fix this??
When I change the third tab on the device toolbar to Built in Microph I get a two squiggly blue lines in both tracks but I think it is recording in mono. Which setting should I have this on -
Built in Microph, Built in input or USB PnP Audio Device.
Does the tape unit have RCA sockets that you can connect to a hi-fi device or boombox to test to see if it outputs two channels there? Or does it have a headphone jack that you can plug headphones in to test for two channel stereo.
Neither of these tests would rule out faulty USB services on the in-built soundcard in the USB tape unit.
Thanks for all your help. Unfortunately I bought the piece of equipment over 2 years ago in Australia. Currently in West Africa so I will probably have to delay this project until I get back to Aust and try and get the turntable/cassette player fixed.
Does the player have RCA leads our as well as the USB - or does it have RCA sockets. If so you should be able to jack-in to your MAc’s line in (it does have a line-in?). This will by-pass the soundacrd in your TT/cassette deck and use your MAC’s onboard soundcard instead.
Or do you by any chance have a stand-alone cassette deck that you can similarly plug direct to the Mac’s line-in?
Thought I would let you know I rang a Lenoxx Service Centre in Australia and explained the problem and they think I have a dirty head on the tape player. Will try to clean tonight and see how I go.
One other question
I have been recording each song individually i.e. save project as for each song they are being saved as per the following
James Bond theme_data
James Bond theme_aup
When I save I get a message that I need Audacity to play back etc.
After saving in this format (aup) can I export to another format??
Also can I export to an I pod??
I intend to do the tutorial when I return to Australia (March 2013).I bought the system in Australia while on holidays 18 months ago and returned to Zimbabwe. The internet bandwidth there wasn’t good enough to do the online tutorials. Very slow .
You can’t use Audacity project in anything but Audacity so you must export audio files if you want to play them on an MP3 player or iPod or any software player. See this page in the Audacity manual: http://manual.audacityteam.org/o/man/audacity_projects.html
You can use many different export formats on an iPod - you could use WAV or AIFF but these produce huge files and will overfill your iPod quickly - most folk would use MP3 or AAC (Apples compression format). You can export MP3 or AAC from Audacity (tou need to download LAME and FFmpeg software for that). Personally I export 16-bit WAVS import those into iTunes and use iTunes to convert them to AAC (I use 256 VBR). This is my workflow for that which I documented for the Manual: http://manual.audacityteam.org/o/man/sample_workflow_for_exporting_to_itunes.html
