Please excuse a newbie, but I can’t seem to get my project onto a single track. If I pause or stop on my initial track, when I start again it’s on a different track. Is there a command to stay on a single track? Thanks in advance, Gene
Before you stop, press pause P. Press P again to start up again.
After you stop, you can Append Record with Shift-R.
In the current version of Audacity use Transport > Append Record - or hold the Shift key and click the Record button or use the shortcut Shift+R
In the next release we are changing this so that just pressing Record wikk record on the same track - and the Shift+Record will record on a new track.
BTW the easy way to line all your tracks up if they are stacked up like that
a) Ctrl+A to select all
b) Tracks > Align Tracks > Align End to End
Then to make a single track
c) Tracks >Mix and Render
