I got Steve's email (and would probably have seen this thread when I logged on the board immediately after reading my email <grin>).
I still use Audacity extensively (but I have not updated beyond 2.0 for reasons which have little to do with Dragon). I am using DPI 15 & KnowBrainer 2017 and AutoIT3. KnowBrainer 2017 is a very useful tool which works along with Dragon and is available at no cost if you are disabled. AutoIT3 is a compiled Basic-like scripting language which is free. Due mainly to RSI I have very limited ability to keyboard or mouse.
I have converted all of my Audacity Dragon commands into KnowBrainer commands (the code is almost always exactly the same it just runs way faster on KnowBrainer). Many of my commands are screen resolution/window size and position/toolbar dependent. I have also made a few significant modifications to Audacity to make it more Dragon-friendly.
All that being said… I control Audacity virtually completely by voice. I have lots of spare time and am happy to help anyone do the same.
Aurah2 wrote:I am trying to get in touch with forum user Edgar.
How may I help?
In no specific order, here are my current Audacity editing commands:
Trim Back
Trim Front
Clean Silence
Export Them All
Change Export Location
Fix Name
Transfer <1to100> Labels
Slow Tab <1to20>
Center Label
Zoom Selection
Zoom Back
Zoom Front
Generate Silence Dialog
Skip To Here
Insert Time <dictation>
Pauls D Click
Brick Wall Limiter
Amplify Down <1to20>
D Clicker
DC Offset
Noise Reduction
Silence <THISorTHAT>
Repair <THISorTHAT>
Pauls D Click <THISorTHAT>
Compress <THISorTHAT>
Close <THISorTHAT> Project
Amplify <THISorTHAT>
Normalize <THISorTHAT>
Jump To Here
Export Then Exit
Pro Fade Out
Tail
Play Here At Speed
Trim Both
Trim Dialog
Mark Silence
Mark Silence Dialog
Find Silence
Remove Leading Label
Analyze Vinyl Track Gaps
Export These Tracks
All Done
Export With New Name <1to20>
Analyze Custom Track Gaps
Analyze CD Track Gaps
Create Profile
Apply Noise Reduction
Get Profile
Remove DC Offset
Tale
Select Text
Insert Final Label
Silence Finder
Display Labels
Analyze Tiny Silence
Get Another Name <1to20>
Make Labels
Remove Label
Repeat Effect
Remove Track Gap
Find Zero Crossing
Edit Labels
Fade In
Repair
Wave Export
Export And Close Project
Apply Wave Chain To All
Apply Wave Chain
Preferences
Trim Silence
Adjustable Fade
Amplifier Dialog
Rename Before Exporting
Silence Audio
Select All
Compressor Dialog
Compressor
Amplify Down One Half
Inspect Front
Make It Fit
Inspect Back
Amplify Everything Up <1to10>
Amplify Everything Down <1to10>
Remove Rumble
Amplify Up <1to10>
Repair Clicks
Mono To Stereo
Split Stereo Track
Make Stereo Track
Remove Clicks
Fix Clipping
Normalize
Remove Noise
Trim Front
Add New Track
Export This MP4
Trim Back
Export Overwrite
Export This Video
Export Project
Prepend <1to10> Tracks
Append <1to20> Tracks
Remove Last Bit
Close Inspection
Scroll Right <1to100>
Scroll Left <1to100>
Exit
Play Preview <1to20>
Change Playback Speed Moderate
Change Playback Speed Slow
Change Playback Speed Fast
Remove Those Labels
Remove Front
Remove From Here
Fit Vertically
Insert Leading Label
Select Between Labels
Export Selection
Draw Tool
Add Leading Label
Remove Trailing Label
Zoom Here
Sync Lock Tracks
Page Left
Page Right
Insert Label Here
Play From Start
Played Here At Speed
Edit Metadata
Insert Blank Label
Play Here
Preview Cut
Close Track
Export
Play At Speed
Stop Here
Append Second Track
Close Top Track
Track Panel
Add To End
Open Metadata Editor
Analyze Silence
<DELETEorCUT> To End
Get To End
Zoom In <1to20>
Zoom Out <1to20>
Zoom Tool
Selection Tool
Zoom Out
Stop
Play
Zoom In
Home
End Of Track
Fit In Window
Insert Label
Export Multiple
Save Project As
Create New Track
Quit
New Project
Import Audio
