I love classical music how do I import into audacity ?..one way is to patch the headphone into the mic …if so I need to turn off the the laptop mic …can i turn mic off inputting into audacity …but surely audacity can be internally imported should be simple…Len
What operating system are you on? and what audacity version are you using?
Depending on operating system and sound card used you may or may not have an option for stereo mix in the Devices Preferences.
Hi,
Have you managed to get this done? I am experiencing the same problem and would like to know how were able to solve it. Any help would be greatly appreciated. Thanks.
See this tutorial from the 1.3 manual: http://manual.audacityteam.org/man/Tutorial_-_Recording_audio_playing_on_the_computer
