Records on desktop but not laptop
renlute
Post by renlute » Fri May 11, 2018 5:43 am
I've just started to experiment with recording voice and guitar using Audacity. It works fine with:
Desktop system (very fast CPU, no special sound card) with Win 7 -> Audiobox USB -> Rode and Sterling mic -> Audacity 2.1.0
But then I tried with my HP laptop (Celeron N2840 CPU 2.16GHz), Win 8 -> same Audiobox and mics and Audacity version:
I get about three seconds of good sound and then the signal disintegrates into gibberish or no sound at all. What gives? Win 8 (which I don't like)?? Inadequate audio processor?
Thanks for any fixes. I'm meeting a singer tomorrow and was expecting to get some modestly passable recording out of it.
Doug
renlute
Re: Records on desktop but not laptop
Post by renlute » Fri May 11, 2018 6:35 am
Upgraded to Audacity 2.2.2, which gives me more seconds of sound but still lots of gibberish. And though the mic is a foot from the guitar -- either a Sterling (which I think is directional) or the Rode NT1-A which I don't think is directional -- all I hear is voice, no guitar.
DVDdoug
Forum Crew
Post by DVDdoug » Fri May 11, 2018 2:24 pm
Check for any Windows "enhancements".
roadsterUK
Post by roadsterUK » Sat May 12, 2018 8:18 am
Are you recording all tracks simultaneously? If so latency delays are not important so you should try to increase the buffer size in your audio ( microphone) driver setup if you have that option. Failing that you will have to reduce the sample rate so that the laptop will have enough processing power to keep up.
