Vamp Aubio Onset Detector not working right Audacity 2.2.2
Re: Vamp Aubio Onset Detector not working right Audacity 2.2
Post by steve » Tue May 15, 2018 4:15 pm
frew_frew wrote:(I just don't recall having to make a selection from time=0.0)
Old versions of Audacity had quirk that if nothing is selected and you apply an operation that requires a selection, the entire project would be selected automatically.
In more recent versions of Audacity that "auto select all if nothing selected" does not happen by default (though it can be enabled in preferences).
frew_frew
Post by frew_frew » Tue May 15, 2018 7:48 pm
I see, okay...thanks Steve for all your help and insights with this.
