Quickly getting to the beginning and ending of a recording
zpntenergy
Post by zpntenergy » Wed May 02, 2018 1:53 am
I am just starting to learn about Audacity, so my question is very basic. After I record something, how do I quickly jump back to the beginning of the recording so that I can edit out any blank space which was recorded before the beginning of the recorded audio. Also, once I've done that, then how can I then quickly jump to the end of the recording so that I can edit out any blank space there at the end? I'm using Windows 10 pro, and Audacity version 2.1.3. Since I'm new at this, if you answer this question, I won't even know where I should look for your answer. Should I look back here at this forum? Thanks! Carl
Trebor
Re: Quickly getting to the beginning and ending of a recordi
Post by Trebor » Wed May 02, 2018 2:53 am
zpntenergy wrote: how do I quickly jump back to the beginning of the recording
"J" or "home" keys.
zpntenergy wrote:how can I then quickly jump to the end of the recording
"K" or "End" keys.
waxcylinder
Post by waxcylinder » Wed May 02, 2018 11:05 am
or the Skip to Wnd/Beginning buttons in the Transport Toolbar
See: https://alphamanual.audacityteam.org/ma ... lbar#start
