corrupted recording - Win10 - v 2.2.2
ilpelle
Post by ilpelle » Tue Apr 24, 2018 9:12 am
Hi
very often the recording suddenly gets corrupted (see the attached image): there is something that I can do?
Many thanks in advance.
ciao
ilpelle
corrupted recording.png (105.14 KiB) Viewed 275 times
Reason: Put image inline to preserve board layout
Re: corrupted recording - Win10 - v 2.2.2
Post by steve » Sat May 12, 2018 12:38 pm
ilpelle wrote:very often the recording suddenly gets corrupted (see the attached image)
It is not clear from the posted screenshot what you are complaining about.
Perhaps something here may help: https://manual.audacityteam.org/man/faq ... oting.html
ilpelle
Post by ilpelle » Sun May 20, 2018 3:18 pm
thanks for your answer Steve
the link is very useful :)
actually I've solved the issue with changing the laptop (probably it was something about a very "aggressive" anti virus)
ciao
ilpelle
