DeBreath in Audacity : proof of concept
Trebor
Post by Trebor » Wed Apr 18, 2018 10:35 pm
Using DtBlkFx , equalizer & AutoDuck ...
click on this animation to see it in its entirety
DeBreath - proof of concept.gif (195.8 KiB) Viewed 455 times
For more info on DtBlkFx, see ... https://rekkerd.org/dtblkfx/
Re: DeBreath in Audacity : proof of concept
Post by steve » Thu Apr 19, 2018 3:50 pm
I can see what you're doing with Equalization and Auto Duck, but what is DtBlkFx doing?
Trebor
Post by Trebor » Thu Apr 19, 2018 9:15 pm
steve wrote:... but what is DtBlkFx doing?
I'm not 100% sure myself :oops: . AutoHarm on "between" emphasizes non-harmonic sounds, like the inhale noise ...
So can be used to isolate the inhale noise. The equalization, (after DtBlkFx), separates the inhale noise from eff & ess noises.
DtBlkFx uses FFT which I believe is possible via Nyquist , but is way over my head.
Post by steve » Fri Apr 20, 2018 8:16 am
It might be interesting to compare how well this technique works with and without the DtBlkFx processing.
Trebor
Post by Trebor » Fri Apr 20, 2018 9:23 am
steve wrote:It might be interesting to compare how well this technique works with and without the DtBlkFx processing.
The DtBlkFx processing is essential : it emphasizes the non-harmonic sounds, (hissy noises).
inhalation breath sound in middle and at end of audio
DtBlkFx is essential to isolate inhalation sounds.gif (371.54 KiB) Viewed 421 times
Equalization alone is not sufficient to isolate the breath sounds.
