Can't change my track to mono
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
sp_london
Post by sp_london » Wed Apr 18, 2018 8:34 am
Hi - I'm trying to reduce the vocals on a track to make a karaoke backing. I've been following a YouTube tutorial and I have successfully imported the audio track, then split the single track into two separate ones, then selected the second and inverted it. Next it says I must change the tracks back to mono but this is greyed out for me so not possible.
I'm on 10.11.5 Mac - it's a track recorded in the 90's (if that's relevant?!)..
Re: Can't change my track to mono
Post by steve » Wed Apr 18, 2018 10:43 am
Which version of Audacity are you using? (Look in: "Audacity menu > About Audacity").
