Inability to zoom waveform vertically
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 1:12 pm
To zoom waveform vertically, 2.2.2 made it harder: a right click, then a left click is needed. Previously this was left click. Please fix this.
Re: Inability to zoom waveform vertically
Post by steve » Sat Apr 14, 2018 1:31 pm
See here for information about the new vertical zoom behaviour: http://manual.audacityteam.org/man/vert ... oming.html
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 1:40 pm
You called half of the old behavior the "Advanced" one. Which is strange. The other half (right-click zooming out) cannot be restored, because right click is always that context menu that reminds me of a Command Prompt.
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 1:43 pm
Also, I noticed a design flaw: the first zoom in may exceed 1 or go below -1, and in this case a further zoom in will reset to the classic -1 to 1 scale.
