Use the selector tool to select a piece of a track.
I decide I don't want to do anything after all
How do I get rid of the selection - this is driving me nuts!!!!?
Selector tool frustration...
Re: Selector tool frustration...
Click once on the waveform (without dragging).raddy59 wrote:How do I get rid of the selection
The simple ones are always the hardest to crack
Many thanks
Many thanks
