WAVES VST Plugins not showing up on AUDACITY
For Musicians to Share Their Music, Tips, Tricks and Reviews.
pennyroyaltea94
Post by pennyroyaltea94 » Thu Apr 05, 2018 7:43 am
OKAY So I installed WAVES ABBEY ROAD STUDIOS EQ VST last week,
I just bought the WAVES C4 Compressor and it won't show up on my new PLUGINS List , what is wrong ?
I even copied the C4 .DLL to the audacity list and won't still enable right.
Trebor
Re: WAVES VST Plugins not showing up on AUDACITY
Post by Trebor » Thu Apr 05, 2018 10:17 am
pennyroyaltea94 wrote:... copied the C4 .DLL to the audacity list and won't still enable right.
Even if you have a 64-bit operating system, Audacity only accepts 32-bit versions of plugins.
Also not all VSTs are compatible with Audacity: some don't work properly in Audacity even if enabled.
pennyroyaltea94 wrote: bought the WAVES C4 Compressor
Gmulti is a free muti(3)band compressor which works in Audacity in Windows.
pennyroyaltea94
Post by pennyroyaltea94 » Thu Apr 05, 2018 8:43 pm
Looks like I wasted $29 this isn't loading right or works with AUDACITY ,
Well the COMPRESS you suggested looks like it has all the elements I am looking for .
Thanks.
pennyroyaltea94
Post by pennyroyaltea94 » Thu Apr 05, 2018 9:25 pm
it works now ,
Online Staff told me this.
Press the [Win Key] + R, type in %appdata% and hit Enter.
Go to Waves Audio and drag the Preferences folder to your desktop (this folder can be removed after troubleshooting is over).
Launch AUDACITY, create a new session with a Supported Sample Rate and try to load your Waves plugins.
Trebor
Post by Trebor » Thu Apr 05, 2018 11:25 pm
pennyroyaltea94 wrote:it works now , Online Staff told me this.
Audacity plugins folder did recently move from ...
Code: Select all
C:\Program Files\Audacity\Plug-Ins
to
Code: Select all
C:\Users\<YourNameHere>\AppData\Roaming\audacity\Plug-Ins
pennyroyaltea94
Post by pennyroyaltea94 » Sun Apr 18, 2021 3:24 am
Just wanted to give an update to this idea.
This is how I get it to work.
COPY AND PASTE Every WAVES Related Plug In named Folder inside the
Audacity APPDATA Roaming Plugins Folder , Not the Plugins Folder that you find in the regular audacity program files folder in PROGRAM 86X or 64X
