Certain audio creates static issues, stumped.
hectorbarbosa
Post by hectorbarbosa » Mon Apr 02, 2018 2:24 am
I cant figure out why certain audio creates static pops on my pc when I pause/unpause, either in the editor itself or after exporting, pausing/unpausing creates a quick pop static sound, no idea why.
I was creating some sfx and it seems to be a recent issue I can't solve.
I am using 2.2.2 & 2.1.2, tested on both, no difference.
I have tried saving as WAV and MP3, no difference.
I have tried updating my audio drivers, no difference.
I tested on speakers and also headphones, pops are still there.
I went and listened to other youtube videos and the issue is still there on some :| so I see this isn't fully an audacity issue but any tips on how I can track down why this is happening?
Anyone else get the static pops when you pause/unpause this audio? I can at least rule out if its just my PC or an audio issue with clips like this.
https://1drv.ms/u/s!AgY8tgPTOKhkgSOJMo62-cPkcsQX
Robert2
Re: Certain audio creates static issues, stumped.
Post by Robert2 » Mon Apr 02, 2018 6:24 am
I get 2 static pops without pausing, and extra static pops when pausing/unpausing.
Trebor
Post by Trebor » Mon Apr 02, 2018 8:17 am
hectorbarbosa wrote:I cant figure out why certain audio creates static pops on my pc ...
Some peaks are too loud : they're off-the-chart ...
''sfx'' is off the chart.png (11.44 KiB) Viewed 335 times
See ...https://manual.audacityteam.org/man/vie ... w_Clipping
hectorbarbosa
Post by hectorbarbosa » Mon Apr 02, 2018 9:39 am
So that is the cause of my static pops when I pause? :/ I also get this popping when listening to other audio too though :? unless those audio sources also just happen to be clipping outside like that.
