hum
lonepilgrim
Re: hum
I think I don`t need to download anything from Source Forge or Nyquest ? When go from C/users/Doug I don`t see a folder named App/Data.
lonepilgrim
Re: hum
success...i got it...i` m still getting too much background noise but this will help...should I adjust the settings and experiment ?
there may be something to the internal mic thing..the documentation on the computer does not have it.there are 2 very small openings near the web cam which btw I`ve been able to get working... there is a new issue...i believe I did use to record...now and then from the computer mic which I cannot find...the driver for it real tech has disappeared...surely something i did to try and get this to work..I cannot get it back...any suggestions? Thanks for getting this for me. I used to use some kind of homegrown auto-tune deal here which although didn`t do much with my singing voice anything would be an improvement.
Re: hum
The Nyquist interpreter is built-in to Audacity. The only thing you need to add are the plug-in files, (which end in ".ny").lonepilgrim wrote:I think I don`t need to download anything from Source Forge or Nyquest ?
"AppData" is a hidden Windows folder, to make hidden folders appear see ...lonepilgrim wrote: When go from C/users/Doug I don`t see a folder named App/Data.
https://www.howtogeek.com/howto/windows ... in-windows
Re: hum
The Mosquito & De-hum plugins don't reduce hiss-type noise. You need noise reduction for that.lonepilgrim wrote:success...i got it...i` m still getting too much background noise but this will help...should I adjust the settings and experiment ?
There are free auto-tune type plugins which work in Audacity, (on Windows), e.g. ...lonepilgrim wrote: I used to use some kind of homegrown auto-tune deal here which although didn`t do much with my singing voice anything would be an improvement.
https://www.auburnsounds.com/products/Graillon.html
http://www.gvst.co.uk/gsnap.htm
lonepilgrim
Re: hum
Thanks..this has really helped alot...my last question is how much is normal for the record indicator light to be flickering?
right now if im recording with no input or if im just monitoring the recording level on a blank audacity project it moves up to as far as 1/2 or 45 to 42
Re: hum
Yes, that's registering the noise floor ...lonepilgrim wrote:... normal for the record indicator light to be flickering?
-42dB of noise is a bit loud for recording music, (but an acceptable level for a phone-call).lonepilgrim wrote: right now if im recording with no input or if im just monitoring the recording level on a blank audacity project it moves up to as far as 1/2 or 45 to 42
The professional standard is -70dB, but you'd need a professional sound-card for your computer to achieve that low noise level.
lonepilgrim
Re: hum
Unfortunately, I am recording music which explains why I`ve had problems in the past with background noise especially when exporting to mp3 or wav..this is a 5 year old lap top which other than this I haven`t had any problems with..I will eventually buy a new desk top computer..do you know the minimum specifications for the sound card or anything else I might need to record music ?
Re: hum
New computer not necessary : there are sound-cards & mixers which plug into the USB socket on the computer.lonepilgrim wrote:..this is a 5 year old lap top which other than this I haven`t had any problems with..I will eventually buy a new desk top computer...
The sound-card built into laptops is adequate for phone-calls : it's not designed for professional recording ...
https://www.youtube.com/watch?v=8tyjHkg4IyI
lonepilgrim
Re: hum
this is a lap top..sounds like it is unrealistic to record music on it..I was planning on buying a custom built desktop anyway..is there anything i need to ask for when I order it? there is a good computer shop near me that will custom build one for me..I am a professional musician and it is my primary reason to do this
Re: hum
Adding a ProSumer audio-interface to a standard computer seems the way to go,lonepilgrim wrote:...I am a professional musician and it is my primary reason to do this ...
see ... https://www.youtube.com/results?search_ ... +interface
